Mowing Attachments
/ Attachments #1
toneychaney
kioti ck20
I have Kubota BX22 tractor with a backhoe and a loader, with the tires so small on this tractor I have a problem finding attachments that will work with my 3-point hitch. Has nayone had this problem? how did you over come it? can you change the tires to a larger size? if so what size could I use on the tractor?
/ Attachments #2
If you can change the tires, remember you have to change all four tires and have them properly matched in a 4WD unit. You may even need new wheels.
/ Attachments #3
They make impliments designed just for the sub compact market. I believe King Kutter makes some. Probably others too. Buy the impliments sized for your machine
/ Attachments #4
The attachments should be designated as Category 0...
/ Attachments #5
I have the same tractor (BX22 w / BH & FEL)...nice little machine. I have a Land Pride rake, carry-all, and chipper...no problems with any of the attachments.
/ Attachments #7
I have a 48" box blade, a 48" scraper blade, a couple of carry-alls, a post auger and a fert. spreader that are all standard Cat I and all fit and work perfectly on the BX. Also have a landscape rake that has reduced dimensions (Cat 0, I guess), but fits pretty much the same as the other stuff.
What implement(s) are giving you a tire clearance problem on your BX, Toneychaney?
/ Attachments #8
I "believe" the BX22 has a "limited cat I" while later ones have "cat I", not much, but a little difference according to some. I used the same implements on our 2200 as 2660, as mentioned, several companies make implements for the BX size tractor.
/ Attachments #9
Land Pride makes a line SCUT implements made for the BX series, right down to the paint color :thumbsup:
Link to this TABLE where the left column has the implements that will git-r-done on the BX.
Skid Steer Rotary Mulcher (A65640)
Skid Steer Rotary...
3pt 55 Gal Rear End Boom Sprayer (A64127)
3pt 55 Gal Rear...
429858 (A61165)
429858 (A61165)
Iranch IRET13 Electric Tricycle (A64127)
Iranch IRET13...
275 Gallon Cage Tanks, Koser Safe, with 2" outlet (A62679)
275 Gallon Cage...
2000 Pro Stock Utility Trailer (A66285)
2000 Pro Stock...
