Mowing Attachments
   / Attachments #1
toneychaney
kioti ck20
I have Kubota BX22 tractor with a backhoe and a loader, with the tires so small on this tractor I have a problem finding attachments that will work with my 3-point hitch. Has nayone had this problem? how did you over come it? can you change the tires to a larger size? if so what size could I use on the tractor?
   / Attachments #2
If you can change the tires, remember you have to change all four tires and have them properly matched in a 4WD unit. You may even need new wheels.
   / Attachments #3
They make impliments designed just for the sub compact market. I believe King Kutter makes some. Probably others too. Buy the impliments sized for your machine
   / Attachments #4
The attachments should be designated as Category 0...
   / Attachments #5
I have the same tractor (BX22 w / BH & FEL)...nice little machine. I have a Land Pride rake, carry-all, and chipper...no problems with any of the attachments.
   / Attachments #7
I have a 48" box blade, a 48" scraper blade, a couple of carry-alls, a post auger and a fert. spreader that are all standard Cat I and all fit and work perfectly on the BX. Also have a landscape rake that has reduced dimensions (Cat 0, I guess), but fits pretty much the same as the other stuff.
What implement(s) are giving you a tire clearance problem on your BX, Toneychaney?
   / Attachments #8
I "believe" the BX22 has a "limited cat I" while later ones have "cat I", not much, but a little difference according to some. I used the same implements on our 2200 as 2660, as mentioned, several companies make implements for the BX size tractor.
   / Attachments #9
Land Pride makes a line SCUT implements made for the BX series, right down to the paint color :thumbsup:
Link to this TABLE where the left column has the implements that will git-r-done on the BX.
2013 RAM 4500 (A50323)
2015 Ford Expedition EL XLT SUV (A50324)
2015 Ford...
2020 CATERPILLAR 320GC EXCAVATOR (A51242)
2020 CATERPILLAR...
Komatsu WA270-8 Articulated Wheel Loader (A49346)
Komatsu WA270-8...
DIRT DOG LLR 72 (A51243)
DIRT DOG LLR 72...
1993 Barrett Gooseneck Livestock Trailer (A50514)
1993 Barrett...
