Attachments I can make money with? What ones am I missing?
   / Attachments I can make money with? What ones am I missing? #11
He handles just Mahindra. The Mahindra hd line is plenty heavy enough on the box blade. Been using one for some time. My grapple will come from EA. Right now I do gravel driveways with my box blade and an asphalt roller. I suppose if I just went in the level on a land plane may work. I really enjoy my results with the box blade but if a land plane is cheap enough one can never have too many attachments
Land planes are not cheap, and while you may think that the Mahindra HD line is heavy, they are not. To be fair to your customers, you should be using a box that weighs at a minimum of 1000lbs. I'm fairly certain that not one of Mahindra's box blades is that heavy.
But if you can get away with lesser implements, more power to you. :thumbsup:
   / Attachments I can make money with? What ones am I missing? #12
No shredder? Lots of people need mowing done.
I wouldn’t waste money on a 3 point post hole digger for any commercial work. You need a hydraulic one for the loader so you can apply down pressure and actually dig.
   / Attachments I can make money with? What ones am I missing? #14
Ok... just off the top of my head... and not really in any order of importance... How about a big area finish mower and perhaps a post hole digger with a big auger head for planting trees for people?
All good ideas. I have looked at the Mahindra brush mowers but never pulled the trigger. Not sure anyone would hire me.
   / Attachments I can make money with? What ones am I missing? #16
A brush hog will be of use but a finish mower not so much. To many big zero turns out there but it may be different in your area. Sounds like you got it covered on implements,maybe rear straight blade. I don’t know how much trailer you have but I can’t carry but so much with me at once anyway.
   / Attachments I can make money with? What ones am I missing? #17
Pulverizer is another option if power rake is too expensive.
   / Attachments I can make money with? What ones am I missing? #18
When I see suggestions to use digging implements commercially I immediately think of all the comments in this forum about the high cost of liability insurance when you start working below the surface. Isn't that a concern here?
I agree. Staying above ground has far less risk to your financial well being.
   / Attachments I can make money with? What ones am I missing? #19
PTO rotary ditcher? Not a lot around my area, and I think people try to figure out what to do to 'make do'. If you could offer to clean out ditches, it would be easy on your machine but might be good for your wallet.
Most useful 'special equipment' I own is my Danuser Intimidator. You might look at it or some variant and offer fence row cleaning, brush removal, etc. Especially if you have a grapple to move the brush afterwards. You can pull a lot of crap with a good FEL puller.
These are cheaper than the Danuser, but I've heard good things. If you look at them, make sure your FEL has the power to pull whatever things you offer. Advertise, 'Up to x" trees removed' etc.
   / Attachments I can make money with? What ones am I missing? #20
Not sure how much work your wanting....but to me... fall lawn renovation.....aeration and overseeding is decent to do. I can make $12 per 1,000 square feet. True green will get up to $16 to $17 dollars per square foot for aearation only. The equipment is expensive but your customers will see results either that fall or the next spring.
I have a new DR Stump grinder. Someone on here mentioned they are a pain....but I have not experienced that at all. It was much much easier to grind that stump than it was to cut down that tree and haul it off. No comparison. It has sharp teeth because it is new and it is mine, and I got the biggest motor that they sell for it....and it crushes the stumps....I mean destroys them...quickly....and I have a huge deep hole outside. I am grinding some stumps this weekend at a business associate's lake house this weekend.
2006 MILITARY SERVICE TRAILER (A52708)
2006 MILITARY...
SARLO MOWER (A55758)
WACKER NEUSON SM120 STAND ON SKID STEER (A52709)
WACKER NEUSON...
2012 DRAGON 130BBL VAC TRAILER (A58214)
2012 DRAGON 130BBL...
Bobcat Skid Steer Auger Attachment (A55973)
Bobcat Skid Steer...
SET OF TRUCK FENDERS AND HARDWARE (A58374)
SET OF TRUCK...
