Attachments For Fertilizing A Lawn???
   / Attachments For Fertilizing A Lawn??? #41
I've been fertilizing and de-weeding my own lawn for a while. First by hand, now with an electric seeder and 25 gallon sprayer on my atv. Now that I have a tractor, a bigger seeder and sprayer are on the wish list. Larger capacity = less stops to refill. I also maintain a 3 acre food plot and the higher capacities would help there too.
-As tchri stated, spreading twice perpindicular to each other will give you the best coverage, whether sewing, fertilizer, lime or anything.
-Spread width will depend on the material you are sewing. Fescue seed may only have a 10 to 15 foot width, whereas pelletized lime and fertilizer could reach 50 feet. For narrow areas a drop spreader would work as previously mentioned, or a hand spreader could too. You could turn the crank slower to lessen the spread width.
-Buy your fertilizer and lime where the farmers get theirs. I get mine at a local feed mill and pay around $5 for 50 lbs. of pelletized lime and $6 to $6.50 for 50 lbs. of fertilizer, depending on the grade. I used to spread high-nitrogen like 27-3-3, but it all goes to the top and doesn't seem to help the roots as much. I've since started using more low-nitrogen, like a 6-24-24. The lawn seems healthier and it doesn't need mowed near as often. I used to fertilize once in fall and once in the spring. This year I'm skipping the spring to see what happens. I read that it's healthier for the lawn.
-For spraying weeds, I get 2-4-D at Rural King (similar to TSC). I mix 1.5 ounces per gallon of water. For stubborn weeds, add 1.5 ounces of brush killer per gallon. I spray the yard 2 to 3 times per year as needed.
   / Attachments For Fertilizing A Lawn??? #42
Indianbowhunter,
I have about the same situation as you. I use to do everything with an ATV. I have this 25 gallon electric spray and a 15' boom. I have this friend, we are going to convert that sprayer to a 3 point hitch, I will put a switch to operate extra lights and power the sprayer when it is attached. I will run that way until the electric pump goes out then buy a pump for the PTO.
Murph
UNUSED 1RGC40 MINI GOLF CART (A57193)
UNUSED 1RGC40 MINI...
Atlas HA-EC60 (A56469)
CRAFTSMAN 60 GALLON AIR COMPRESSOR (A57192)
CRAFTSMAN 60...
Commercial Truck Frame with Axle (A55852)
Commercial Truck...
2009 Honda Pilot AWD SUV (A56859)
2009 Honda Pilot...
UNUSED JCT 84" HYD 4N1 BUCKET (A57193)
UNUSED JCT 84" HYD...
