attachments for a 1641
/ attachments for a 1641 #1
dts1449
WNY
Anybody know what attachments might be available for a 1641? I like the one I've got but could find use for a blower if available, even a small push blade might be handy at times.
Thanks
DTS
/ attachments for a 1641 #2
I'm certain there is a blower for the 1641 as well as two blades. There is a 48" and a 54" blade. I've got the 54" one and the tractor (with weights and chains) will handle some pretty big pushing chores.
/ attachments for a 1641 #3
I have the original attachment brochure - should I scan it for you?
/ attachments for a 1641 #4
My dad has a 1641, he has the Moded 450 0r 451 45 inch blower. It's an awesome snow removal tool. With a little luck and patience you can probably find a used one for around 300 to 500 dollars. I can get the model # for you but if you take the earlier post up on his offer, you'd get that and more info. I think they run about $1300 new. On a gravel drive a blade might work better?
Curt
/ attachments for a 1641 #5
I have a snowblower for a Cub Cadet 1641. If anyone is interested in buying it, I would accept a reasonble offer.
I have used this snowblower at our 2 previous houses and it works very well on both a gravel and a black top drive.
/ attachments for a 1641 #6
Blower - 190-451
Snow blade 42" 190-375
Snow blade 54" 190-376
adaptors required 190-316
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A63689)
Dual Tailwheel...
(INOP) 2022 MACK MD6 WATER TRUCK (A65054)
(INOP) 2022 MACK...
2021 Ford Econoline Box Van, VIN # 1FDWE3FN3MDC22817 (A65563)
2021 Ford...
2018 PETERBILT 567 (A65643)
2018 PETERBILT 567...
3096 (A63117)
3096 (A63117)
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
