Attachments bogging down under load
/ Attachments bogging down under load
Do this. It will run fine but with a load you need to supply the engine with more air and fuel.
If what you state (the engine bogging down) I wouldnt be looking at a hydraulic issue. Fuel and air lacking will cause a loaded engine to bog.
Sorry if I wasn’t clear in my explanation . The engine is running fine in my opinion, but the implements (54”mower, 47”snowblower) are what is bogging down under load. I just changed the plugs and cleaned the air filter, this past fall. I haven’t found a fuel filter but will have a better look and change it. I have a tach to check rpm, to make sure it’s reving to max.Thanks for your advice!
Is this the gas engine garden tractor with a Kawasaki 22 HP engine?
If it is this forum may not have the best experts for a gas engine
Dave M7040
It’s a 2000 JD 445 22hp Kawasaki, mid PTO, 54” deck, 47” snow blower front quick hitch, rear three point hitch. Just a pensioner trying what I can to avoid paying 120.00 an hour for a so called expert to fix it for me . Thanks for your advice.
/ Attachments bogging down under load #14
I would also check the fuel and air filters. If you have changed hyd filter to after market you might want to get a JD one.
Why would that be? Do you really think JD makes their own filters? :ROFLMAO:
PORTA COOL 2000 PORTABLE EVAPORATIVE COOLER (A59823)
PORTA COOL 2000...
2020 DITCH WITCH HX30 VACUUM TRAILER (A59823)
2020 DITCH WITCH...
(INOP) 2014 DODGE CHARGER (A59823)
(INOP) 2014 DODGE...
2011 FOREST RIVER SIERRA CAMPER TRAILER (A60736)
2011 FOREST RIVER...
13042tx (A55973)
13042tx (A55973)
(15) Polyethylene Road Bed Protection Pads (A60463)
(15) Polyethylene...
