   / attachment #1
jake123
mo
Ford 7610
Do they make an attachment to pull behind a mower that will smooth out the yard without harming the grass?My yard is so rough from all the moles in the last couple of years.No,not a roller,that just makes the bumps a little flatter and the ground has to be soft.something that will scratch the top 1/2" or so and fill in the low spots.???????????
   / attachment #2
I know of nothing that will do that and NOT disturb the current grass..
b
   / attachment #3
Hi! The best I think. Is add 1-1.5 in. of TOP SOIL The grass come throw. A trailer and a hand shovel . For levelled You can make an Home made grader with two 4 x4 in.X 6 or 8 ft. You can pull this grader with your tractor on all your land. Good Luck ! Oldmech
   / attachment #6
I just plain em off with the BX23 FEL bucket.
BTW the way you should not post the same thread twice .
Once is sufficent and it keeps the replies all together rather that scattered out all over the board.
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2015 Mack GU813 Mixer Concrete Truck, VIN # 1M2AX13C0FM028499 (A51572)
2015 Mack GU813...
JOHN DEERE 3032E TRACTOR (A51247)
JOHN DEERE 3032E...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2012 Dodge Charger Sedan (A51694)
2012 Dodge Charger...
(6) Bags of Tire Chains (A51573)
(6) Bags of Tire...
