Attaching Soft edge to back blade
/ Attaching Soft edge to back blade #1
bdoyle
Nevada
78 Ford 1600 & 81 Ford 1700, 1980 Bobcat 720
Hello All,
I have a Ford 1600 that I sometimes use for snow removal. I live in Northern Nevada so I don't get that much. We usually get a six to eight in dump, just enough to make a mess of things. I have a 5 foot rear scraper and I purchased a 60X6 1inch thick poly from Fall Line. They recommend support 1 inch from the edge. I was thinking about bolting it on top of the scraper blade with some metal straps running down the length of the blade. This would require that the poly take the arc of the scraper blade. They suggested mounting between the blade and the scraper but that would not give the proper support. Unless I drill new holes to mount the scraper higher on the blade. What do you think??
Thanks!
Brian
HARDEE GATORTAIL PTO PUMP (A63291)
HARDEE GATORTAIL...
2015 Ford Transit 250 Cargo Van (A61573)
2015 Ford Transit...
2016 Hyundai Sonata Sedan (A61574)
2016 Hyundai...
Bish Wide Body Claas Adapter Kit (A63117)
Bish Wide Body...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A64280)
KNOW BEFORE YOU...
(2) 25X10.00-12 TIRES ONLY (A64280)
(2) 25X10.00-12...
