Mid-Mount Mower attaching mid mount mower
/ attaching mid mount mower #1
mkersey000
kubota bx2360
i have had my mmm off all winter and now i want to re-attach it . i can't get the attachment arms to lower. does the three point hitch need to be removed for the mower deck arms to operate? i am a complete rookie at this so please use small words.
/ attaching mid mount mower #2
Welcome to TBN.
Shouldn't have to. But...............
You didn't mention what brand of tractor you have, so the question may be hard to answer precisely.
But if you repost your question in the proper brand specific forum, I'm sure all your questions will be answered quickly.
/ attaching mid mount mower #3
He's got a Kubota BX2360 according to his profile. I'm sure those fine folks that frequentr the Kubota forum can help him...
/ attaching mid mount mower #4
Is the lift mechanism pinned up ?
/ attaching mid mount mower #5
I have a B2620. Sometimes the arms are just tight up there and a bit of a boot make them drop. That is assuming the height adjuster is adjusted to the bottom top level not the top.
i will check the pinned up issue and give the arms a good boot also thanks
got it done! only took about 10 minutes.the deflector plate for the hydraulic cooling fan was not in the way. i worked the 3 point hitch up and down a few times then gave the mower lift arms a good boot and they dropped all the way down. after that it was cake. thanks for the help.
KUBOTA BX2380 TRACTOR (A62130)
KUBOTA BX2380...
240156 (A56859)
240156 (A56859)
1005 (A61166)
1005 (A61166)
2011 DOOSAN G25KW GENERATOR (A60736)
2011 DOOSAN G25KW...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
Toro Greensmaster 3150-Q Riding Mower (A56859)
Toro Greensmaster...
