Attaching hydraulic hoses together
   / Attaching hydraulic hoses together #1
otherguy
MO
Kioti DK45SE
I am new to tractors but I bought a tree puller for my tractor that attaches to the FEL arms. So I had run hose from the auxiliary ports in the back of the tractor up to the front as the tree puller only had three or four feet on it.
As you can see in the pictures this is what I have temporarily done just to kind of hold the hoses there, but the problem is trying to connect the two fittings together.
Is there some trick to getting the fittings to snap in place easily?
Do I need to somehow attach the hose fittings coming from the back to the tractor so they don't move when I try to push the fittings together?
I just find it a real struggle to get these fittings together when things are moving around while trying to hold the collar back and then when a little fluid leaks out then it gets even worse.
Just looking for thoughts or maybe I am missing something on hooking these up.
Thanks
   / Attaching hydraulic hoses together #2
Sounds like you have residual pressure in your lines. Tractor is off, correct?
Yes, its has always been off when I am trying to connect.
   / Attaching hydraulic hoses together #4
One of the key things in hooking up hydraulics is relieving pressure. Very often things are unhooked when they are cold then need to be hooked up when they are warm, and the oil has expanded.
There's the hitting the ball with wood, waiting for stuff to cool, dousing with cold water to cool and many other options.
Lot's of threads here about various ways.
   / Attaching hydraulic hoses together #5
with loose female couplers like you have it can be a real pain to keep the collars pulled back while holding the fitting from sliding back in your hand while trying to insert the male end. They are usually in a bracket which holds the body for you. Such as this
Double Breakaway Clamp With Offset Bar For Hyd. Couplers
   / Attaching hydraulic hoses together #6
It’s going to be nearly impossible with both sides of the line being loose. If you mount them on a bracket and bleed the lines properly before discounting the couplers you won’t have any problem with reconnecting them.
   / Attaching hydraulic hoses together #7
From your pic it looks like the hoses you have cable tied to the loader arm will get pulled back when you raise the loader. The hose should be run up by the loader's pivot point with some slack left at that point. Copying how the existing hoses are laid out is a good way to go (and it'll look neater too).
   / Attaching hydraulic hoses together #8
Ditto...
Dale
   / Attaching hydraulic hoses together #9
I agree with ericm979 that your hoses might be a bit short. The ideal would be to run them up the mount then right along the arm of the FEL. Securing the fittings in a bracket would also solve the two-hands problem. I set mine up with SS flat-face couplings so I don't have to hold the ring back to push them together...I still need a bracket mount, though, to keep the fittings from rattling around and banging the paint off my FEL arms.
I have lot's of extra hose coiled up in the back because I didn't know how much I needed. Will look at running them where suggested and get a bracket that someone posted.
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
1/4 '' Wolverine Universal Quick Attach Mount Plate (A51573)
1/4 '' Wolverine...
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
Laymor SM450-ST Sweeper (A51573)
Laymor SM450-ST...
STORAGE FEES (A52577)
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
