attaching curtis snow plow hydrolics to my 3720 cab
   / attaching curtis snow plow hydrolics to my 3720 cab #1
B3200
Bronze Member
Erie Pa.
kubota b3200
I just bought a 3720 cab deere and plan on transfering my curtis power angle snow plow from my kubota b3200 (no cab)to my 3720, my question is getting to mount the power angle unit that is now attached to my 3200's roll bar to the inside of the 3720's cab. is there a simple solution, I don't see one, (going on a 300cx loader)
   / attaching curtis snow plow hydrolics to my 3720 cab #2
Do you mean the valve? Not sure what the "power angle unit" is...
If so, then a electric diverter setup is the best since the you can operate it electrically inside the cab, you dont want to mount a regular valve in the beautiful cab!
Sorry, i thought this was going under the john deere forum
yes the valve unit, thanks, one of many more things i'm going to learn about this tractor.
   / attaching curtis snow plow hydrolics to my 3720 cab #5
It really should be in the hydraulics forum, ask a mod to move it...
You could also use the 3rd SCV kit form John Deere and, the 3rd function kit for your loader. Clean factory install.
Thanks, i will check monday, I have to see the dealer anyway for the correct fel mount for the curtis plow.
1992 Ford E-350 Ambulance (A51692)
1992 Ford E-350...
2000 Mack CH613 Day Cab Winch Truck (A53117)
2000 Mack CH613...
2016 John Deere 5055E 55HP Utility Tractor (A52377)
2016 John Deere...
2019 Cummins 7.5HDKAT 7.5kVA Portable Diesel Generator (A51691)
2019 Cummins...
2018 Bobcat T590 (A50123)
2018 Bobcat T590...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
