Atlas 1704 excavator
   / Atlas 1704 excavator #1
mark soothill
Kwekwe Zimbabwe
Ford new holland TS90, TS80, 2 x landini and a atlas 1704 excavator
we have an Atlas 1704 excavator, we have had the main pump redone, the motor has been redone, the injectors have been re-shimmed, yet when we start it up it runs well but after about 1 hour of working it becomes very slow and sluggish. at idling speed it is wonderful but as soon as one picks up the revs it sounds as if there is fuel starvation. We are now at our wits end, can a member please give us some kind of assistance.
   / Atlas 1704 excavator #2
I'm not terribly familiar with Atlas other than the newer rebadged Terex machines. But is it by any chance a Duetz engine? Or air cooled engine of any type. Also is it turbo charged. I used to operate a Leibherr excavator with a duetz engine and it had some dust on the cooling fins but the sending unit for the temp was bad. It would let the engine overheat a bit and get sluggish. But I've also had a turbo that was going out do the same when it got hot it would lose efficiency.
UNUSED LANDHONOR ABC-13-125A HYD BRUSH CUTTER (A54757)
UNUSED LANDHONOR...
Pull-Behind 66in Smooth Drum Ballast Roller (A51691)
Pull-Behind 66in...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A54607)
2015 FREIGHTLINER...
2016 UTILITY 53FT REEFER TRAILER (A54607)
2016 UTILITY 53FT...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A54757)
UNUSED WOLVERINE...
2016 KENWORTH T270 S/A SERVICE TRUCK (A51406)
2016 KENWORTH T270...
