ATF pump in tank system...
/ ATF pump in tank system... #1
/pine
Super Star Member
I have salvaged (from a dumping flatbed) a pump w/valve built into its own tank...Direct Mount Pumps and a compatible cylinder...
This pump can be powered by PTO, or a gas or electric motor...I intend to make a dumping trailer so I will be using either gas or electric power of which I already have both options...there are pros and cons for both but that is not what this is about...
The thing about this system is...it uses ATF fluid (as per manufacturer)...I was thinking it might be handy to be able to use this pump for something other than just the dump trailer..i.e., a wood splitter...my dilemma is if I make a splitter to quick connect to the trailer system because of the fluid I can't connect it to my tractors remotes...
I suppose one option is having a second cylinder and hoses...one for the trailer system and one for the tractor to run the splitter...?
This pump only puts out 1.8 GPM so it is very limited to what it can be used for...anyone have any feedback or suggestions...I'm just looking to get the most out of what I have.
I know it would be slow for a splitter...it always worked the dump bed well
below are the specs on the pump...
* GPM - 1.8 @ 1000 RPM
* Displacement/Revolution - 0.45 cubic inches
* Maximum Pressure - 3500 PSI
* RPM - 300 to 1000
* Maximum RPM - 1000 RPM
* Rotation - Bi-Rotational
This pump is built into the tank with the valve on top...
/ ATF pump in tank system... #4
You should be able to use your splitter oil in the new found pump set-up with no problems.
/ ATF pump in tank system... #5
I agree with Dawze. Just try to get as much of the old ATF out first.
ISZ
2017 HAMM H12i PADFOOT ROLLER (A65053)
2017 HAMM H12i...
2022 CATERPILLAR 914 WHEEL LOADER (A65053)
2022 CATERPILLAR...
Club Car Carryall 6 Medical Utility Cart (A64553)
Club Car Carryall...
2020 23 Ft. Godfrey Marine Hurricane Boat with 26ft T/A Boat Trailer . (A64557)
2020 23 Ft...
2008 PROCO 130BBL (A65643)
2008 PROCO 130BBL...
2017 Chevrolet Tahoe SUV (A64194)
2017 Chevrolet...
