ATF pump in tank system...
   / ATF pump in tank system... #1
/pine
Super Star Member
I have salvaged (from a dumping flatbed) a pump w/valve built into its own tank...Direct Mount Pumps and a compatible cylinder...
This pump can be powered by PTO, or a gas or electric motor...I intend to make a dumping trailer so I will be using either gas or electric power of which I already have both options...there are pros and cons for both but that is not what this is about...
The thing about this system is...it uses ATF fluid (as per manufacturer)...I was thinking it might be handy to be able to use this pump for something other than just the dump trailer..i.e., a wood splitter...my dilemma is if I make a splitter to quick connect to the trailer system because of the fluid I can't connect it to my tractors remotes...
I suppose one option is having a second cylinder and hoses...one for the trailer system and one for the tractor to run the splitter...?
This pump only puts out 1.8 GPM so it is very limited to what it can be used for...anyone have any feedback or suggestions...I'm just looking to get the most out of what I have.
I know it would be slow for a splitter...it always worked the dump bed well
below are the specs on the pump...
* GPM - 1.8 @ 1000 RPM
* Displacement/Revolution - 0.45 cubic inches
* Maximum Pressure - 3500 PSI
* RPM - 300 to 1000
* Maximum RPM - 1000 RPM
* Rotation - Bi-Rotational
This pump is built into the tank with the valve on top...
   / ATF pump in tank system... #4
You should be able to use your splitter oil in the new found pump set-up with no problems.
   / ATF pump in tank system... #5
I agree with Dawze. Just try to get as much of the old ATF out first.
ISZ
2025 CFG Industrial MX12R (A50123)
2025 CFG...
2020 KUBOTA RTV...
1996 Allegheny 35FT 25 Ton Flatbed Equipment Trailer (A51692)
1996 Allegheny...
2001 HAULMARK ELITE II 8' X 24' CARGO TRAILER (A51247)
2001 HAULMARK...
2012 Ford Expedition XLT SUV (A51694)
2012 Ford...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A53426)
2018 INTERNATIONAL...
