atatchment for David Bradley walk behind
/ atatchment for David Bradley walk behind #1
westfreightlines
Flint, MI
David Bradley
I have a David Bradley walk behind tractor. I want to add a hydraulic pump to run some implements I am building. Such as a rotary plow, air compressor and other things. The tractors engine has been replaced with a 6hp Honda motor.
What size pump is good and what size motor can I run. Also advise on plumbing is helpful (pump to relief valve to spool valve to motor to filter to tank ???)
I am going to make the pump and controls a removable attachment. Thank you, D West
/ atatchment for David Bradley walk behind #2
That engine can run a pump at 3.1GPM at 3000 psi.
How fast do you want the motor to run?
/ atatchment for David Bradley walk behind #4
3.1 GPM into a .35 cu in motor will develop a speed of 2046 rpm.
Torque will be 165 in lbs using a 3000 psi figure.
Not a whole lot to work with.
2019 KENWORTH T680 (A65643)
2019 KENWORTH T680...
2012 FREIGHTLINER 114SD ROLLOFF TRUCK (A59909)
2012 FREIGHTLINER...
EZ-GO Electric Golf Cart (A64127)
EZ-GO Electric...
New/Unused Wolverine 3 Point Hitch Attachment (A65583)
New/Unused...
2018 John Deere 5125R Tractor (A64047)
2018 John Deere...
ATS Mini Excavator (A66285)
ATS Mini Excavator...
