At what temp do you use your block heater (of any kind)
   / At what temp do you use your block heater (of any kind) #1
mswlogo
NH, USA
Kubota B2320 DT (Gear)
What does the temp need to drop to before you bother plugging it in?
   / At what temp do you use your block heater (of any kind) #2
Personally I will start using my inline coolant heater on the tractor when the temp drops below 10C. Probably not necessary but I like to think I baby it sometimes. I'll plug it in for it 15 to 30 mins.
On my cars I don't use them much at all. Perhaps if we got more minus 20C weather I would.
   / At what temp do you use your block heater (of any kind) #3
I'm like Tig with the tractor. On the truck I wait till -15C.:D
   / At what temp do you use your block heater (of any kind) #4
Yikes! You guys do baby your tractors.
I've used mine about once so for and it gets pretty cold up here. I really ought to use it in the winter time but the problem is that I don't tend to think in advance that I am going to be tractoring so don't plug it in.
I need some sort of remote way to get it to start when I am in the house and make up my mind that I want to clear the driveway an hour from then or something.
   / At what temp do you use your block heater (of any kind) #5
I use mine when it is below 25f. Tractors and RAM Cummins alike.
Did you mean -10C?
   / At what temp do you use your block heater (of any kind) #7
I never plug in my tractor or truck until the temps are in the teens (F)--with good batteries I've never had trouble starting either one. I do have my truck block heater connected to a timer, which allows it to come on automatically about two hours before I'm going to leave if cold temps are predicted.
Regards, Mike
   / At what temp do you use your block heater (of any kind) #8
I follow a similar rule as ccsial. When the temp drops below freezing I'll plug the tractors in for ruffly an hours, below 0f longer. Never have a problem.
   / At what temp do you use your block heater (of any kind) #9
mswlogo said:
Did you mean -10C?
No, just 10C. I'll plug it in for 15 mins to take the chill out. Not that it's really necessary.
   / At what temp do you use your block heater (of any kind) #10
10C is 50F. That seems a little high. I plug the diesels in when it gets down to 10F-15F.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Case 621D (A57148)
Case 621D (A57148)
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
