AT what RPM do you engage your cutter?
   / AT what RPM do you engage your cutter? #1
bilrus61
Platinum Member
kubota 4200
I have a Kubota L5040 and a JD mx6 cutter. I usually engage the mower at about 1500 to 1600 RPM. It lugs the engine down to about 800 RPM then revs back up. Also do any of you "feather" your PTO engagement? Like just touch it to get the blades turning then really engage it?
   / AT what RPM do you engage your cutter? #2
at an idle with all pto implements
   / AT what RPM do you engage your cutter? #3
Idle, which is 1050. Try to feather the clutch a little
   / AT what RPM do you engage your cutter? #4
Per the JD 3038e manual, pull the PTO knob at 1500 and then throttle up to 2500 to get the PTO to 540... (PTO is electronically engaged)
Nick
   / AT what RPM do you engage your cutter? #5
Engage at about idle. I have done that on all my tractors and it seems kinder to the equipment. Actually, with an old cutter like mine, engaging at too high an rpm will break the sheer pin.
   / AT what RPM do you engage your cutter? #8
I always start easy- try to shift in to pto about 1200 rpm and get the blade turning lightly, then shift into gear as I increase the RPM to 1500- when its moving and the blades are turning (not cutting) I shift the RPMs higher to 1800 -2000. By them I am cutting. I usually cut at that rpm- 2400 rpm is 540, but I don't like all that extra noise of the engine- wasted power and its going fine. The fields are bumpy so I am in M, 2nd on my 9x3 tractor. I could go faster, but I like to stay seated- not bouncing around the place with every rough spot of ground left over from the wet spring.
   / AT what RPM do you engage your cutter? #9
I engage my 10' cutter on our 8540 at about 1200 or so and engage as per manual, basically not abruptly, but not real slow, on the 5740 with 6' cutter about the same though I am still getting use to the push button engagement and may or may not modify, engaging any lower than 1200 causes mine to bog down too much.
   / AT what RPM do you engage your cutter? #10
Since my cutter is not very large, (low rotating mass) I engage and disengage at idle. It does not bog down the engine.
James K0UA
2018 Freightliner Day Cab, Detroit Diesel, Auto (A52384)
2018 Freightliner...
2013 Chevy Silverado 2500 HD (A53473)
2013 Chevy...
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
LOAD OUT INFORMATION LOT NUMBER 4 (A53084)
LOAD OUT...
JOHN DEERE 7300 (A53084)
JOHN DEERE 7300...
2018 Suzuki KingQuad 750 AXi 4x4 ATV (A51691)
2018 Suzuki...
