At the point in my life.....
   / At the point in my life.....
What does a 20 year old B7500 sell for these days??
There's a rough one at another dealer bout 5 miles from me, 1k hrs, same setup, for $9k, supposedly this ones in great shape, all maintenance done regularly, I think the dealer said 400 hrs, and was thinking $10k. I'll find out tomorrow when they drop it off for a free weekend.
3pt & SSQA attachments are standard. Anything meeting the spec will fit on your machine. Pin on buckets & forks are less standard but can be swapped out. Everything else is a propitary crap shoot at best. You can't count on a current production MMM to fit all current machines from a given manufacturer much less one from 5 or 20 years ago.
If you don't get a loader, front mount snowblower, backhoe or MMM with your machine it's going to be a lot of effort & expense if even possible to get them later. You can fab up your own mounts or adapters if you have enough skill, but thats a high effort or expense path forward. Those impliments rarely come up for sale used.
It comes with the loader & MMM so you are mostly there. Putting a 3pt blower on the back would be easy later but you get to blow snow looking backwards. I wouldn't look at it as a deal killer, just be aware the front blower may not be easy. Either look at using the bucket, getting a 3pt blower or hoping you get lucky & find a used or new blower eventually that may need fab work to fit.
Front blowers are 2-3 times the price of a rear 3pt blower & often not as stout. Mostly due to the propitary mounts.
Hmmm...... that's a bummer, but not a deal breaker. Was thinking, my mom (71 yo.) Has a 2011 Silverado with a plow on it we use now. Might just buy this, use it for 5 or 10 years till ma decides to get rid of the truck or it dies, and sell this one, then buy one with all the goodies!
Had a B7500 HST with a mm mower, back blade, front snowblower, and tiller - purchased new in 2001.
Was a great little tractor; worked it hard and it performed well. Even accidentally put some gas in it once. Drained it, refilled it, and ran fine
Traded up to a larger tractor around 2005 because I bought more land and the needed something larger to handle the field mowing.
It should serve you well. If not, as you say, you could probably just sell it for what you paid for it and get something different.
Got a 2011 silverado with a plow on it we currently use, after that dies, might sell this one (providing I get it) and buy a new one with all the goodies.
   / At the point in my life..... #14
Excuse my opinions- they're just opinions, but I'm guessing you're going to want a larger tractor for the property you mentioned. I'll start with this; front mount snow blowers are iffy, especially compared to a rear, PTO driven blower. A bigger tractor with a front blade would perhaps be more useful. You are right about tractors, at least good ones, holding their value and not selling cheap. Sounds like you are informed about different used tractors' values, and features, which is all good!
Not sure if a MMM is ideal, but I don't know your situation, of course. Rear mowers seem better unless you're cutting a smooth lawn, and then, why not a quick zero turn?
It took me three tries to get my Goldie Locks' Kubota tractor- my first, a B8200, was too small, and its gear drive wasn't what I needed (good for mowing large areas, but otherwise, no...). Second was a nice L3130, bigger, heavier, not a lot of power but very capable if you weren't in a big rush, but too big and heavy. Lastly, a super clean used L3400 (HST a must, for me I've learned), which had all the features I had learned I wanted thru my own experience: SSQA loader- which I wouldn't be without, rear remote, extendable rear links. All added by the first owner who had used the tractor simply for mowing almost all of its life, adding the new Kubota loader to it just before he decided to get a bigger Kubota. I no longer need it, but I have a 78" front snow blade that works well with it- (signature photo). (neighbor's groundskeeper has a one ton with a V snowplow, and he plows our lane- I just do clean up, and a bucket works for that). FWIW, tippy tractors benefit from simple wheel spacers on the rear- I added 2" each side, which broadened the rear end and helped with keeping it going straight pushing snow. Loaded rear tires help, too. I don't need to operate on hills, but when I do, those spacers give me more comfort. When I had to plow snow, I craved a heated cab, but a cab would just be a hindrance the rest of the time for me.
Long story short: buy a good Kubota, take care of it, and sell it for what you have in it when it's time to move up.
Dont think I'd honestly need bigger, 5 acres gets leased out for straw, the front yard and around the house got anew rider last year 50 in. Hydro cub cadet. So that leaves about a half acre field (extension of lawn, but a little too rough for the cub cadet unless you go 1mph) a trail out back, and 3.5 acres of woods I want to push some stuff around and eventually mow some atv/hunting trails. Played with it today after it was dropped off at 10am, was able to lop off about 2 inches of wet, dewy grass literally 2x faster than the old 1951 farmall cub with what felt like 500hp....
Afraid if I got too big of a tractor
A: wouldnt fit on my 12 ft. Landscape trailer as its rated for only 2k lbs and B: wouldnt really fit in the woods as well. Just my thoughts.
  • Good Post
Reactions: JWR
Oh, forgot to mention, on the 7500 the rear stance is adjustable with the drive flanges, no spacers needed. Just loosen the clamp, remove pin, and slide in or out to set your wheel width. Kinda a cool feature they dont offer anymore, makes me wonder why.
   / At the point in my life..... #17
Sounds like a nice old tractor. Old tractors can be jewels. They were built to last and to be owner serviced and repaired. It could easily last a lifetime.
All 3 pt attachments and almost all PTOs will fit since those are standard size. Many typical service parts including seats, most of the electrics, instruments, tires, hoses etc. are of course all standard.
Anything else external is easy enough for a person with basic mechanical skills to fabricate. Internal engine and transmission repair is very rarely ever needed, even on much older machines.
See if you can get an original factory owners manual and also workshop and parts manuals. Expect the workshop & parts manuals to be expensive but worth it.
From your description of that B7500, I doubt you will do better even if you go up substantially on price.
rScotty
   / At the point in my life..... #18
Patty21 - I have a B7500 HSD-R that I bought new in 2003. I use it with a 60" mid mount mower to finish mow 2-2.5 acres of lawn, with a 59" flail mower to cut 5 acres of horse pasture and 2 acres of former hay field (rough in places). I have a 60" rear blade, the 48" bucket on the front end loader, and a 50" front snow blower (that I bought new several years ago) for snow removal. The B7500 is a solid tractor and has served me well. It now has over 2,600 hours clocked. The front end loader and bucket have recently been converted to quick attach, and I have added quick attach pallet forks. I highly recommend the Quick attach conversion. The B7500 has turf tires.
Best wishes!
Best wishes!
What's the quick attach do? Thought I already had it on this as yesterday I popped on and off the loader in about 3 minutes. (Drop the legs, pull two pins, unhook hoses, curl bucket in to lift mount, back out) sounds like you might be able to answer my question I originally asked, is the snowblower model specific? Like will a new front one for a 2601 work on the 7500?
Patty21 - It now has over 2,600 hours
Good god man! That would definitely take me a lot of years to get that kinda hours!
2019 Doosan LCV6W Towable LED Light Tower (A55851)
2019 Doosan LCV6W...
2019 Chevrolet Tahoe SUV (A55853)
2019 Chevrolet...
AUTO REWIND 12V HOSE REEL (A54757)
AUTO REWIND 12V...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2006 Gehl RS5-34 6,000lb 4x4 Rough Terrain Telehandler (A55851)
2006 Gehl RS5-34...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
