At Home In The Woods
   / At Home In The Woods #3,591
Its a bit late for this - but if you insisnt on cleaning your gutters several times a year, without adding the leaf guards, I'd buy one of those motorized scaffold lifts. :thumbsup:
RadarTech said:
Make sure you get the proper length measurement system with yours, mind had the wrong one and and it just never Did work right.. The boards only got shorter!!!!!
For one of my cuts, I just cut the board using the wrong mark on the board. OOPS!
When I had all the boards cut for the first shelf, I laid out all the boards for that shelf in order to check my work. I found that the OSB was not all exactly the same width and that my original board cuts were not going to work. I needed to provide more tolerance in the framing to allow for OSB that varied in width from the store by 1/4".
I am extremely glad that I checked things for the first shelf before cutting all the boards. Trying to shave 1/4" off the edge of the OSB would have been messy and not much fun.
Obed
radioman said:
Its a bit late for this - but if you insist on cleaning your gutters several times a year, without adding the leaf guards, I'd buy one of those motorized scaffold lifts. :thumbsup:
I have observed something of a common theme in this thread. You guys sure are willing to help me spend my money!:)
Obed
   / At Home In The Woods #3,594
Obed
Well you can't take it with you so you might as well spread it around while your here:D.
   / At Home In The Woods #3,595
Obed
Lol. Cracking up!
   / At Home In The Woods #3,596
Yes, a table saw would be very nice to have. I have seen them on Craigslist and my mouth has watered.
How much does one of these cost?
Obed
Firt off you can get a table saw on sale for $70 at lowes on black friday or similar sale or $90-100 regular. There good enough for stuff like this but would not make fine furnature on one. I know i have one. The blade is about 1 degree from verticle but i dotn make cabinets with it and can probly adjust it if i tried. It sits on its own base as well.
Also if you built a jig for cutting the 35 2x4s you only measure twice screww the jig to the table and use your chop saw to cut them off as fast as you can position them. I worked for a carpenter at a young age, even they do this to cut repetitive cuts like say balasters for a stair case wher eyou need to cut like 75 of them.
Wow, for under $100 I'm tempted.
Yes that sounds like the ticket.
Tonight we finished the framing for the first shelving unit.
   / At Home In The Woods #3,599
Wow! A corded drill?!:confused2: They still make those?:laughing:
If it were me I'd be using a cordless drill driver with impact type oscillating drive to screw in any fasteners fast and with next to no effort or time wasted. Use torx head screws too, and experience no cam out, no broken heads, and no problems whatsoever! Trust me- I've been using these type tools for years and would never again use Phillips, square drive or any other screw to fasten things like you are doing....
I guess there is something to be said for doing it old school: 'something'.
If you were to go to a impact driver you will NEVER go back, except possibly for something that needs extreme torque; which is sometimes better accomplished with a hi-speed corded drill/driver. Where do corded drills plug into again?:)
Here's one example: read the reviews in this add- they're exactly my experience. I turned my electrician on to this and he's never looked back!
BTD142HW 18-Volt Compact Lithium-Ion 1/4 in. Impact Driver Kit-BTD142HW at The Home Depot
I personally have an early model 14.4 volt and it rocks- but the newer 18+ volts are twice as good- I've used both and the 18+ will outdrive the 14volt by far- it's way faster and it will drive huge lag screws for decking, etc.
   / At Home In The Woods #3,600
I agree once you use a cordless impact you won't know how you got by without one.
I got tired of buying batteries for my cordless tools (makita, milwaukee etc) and just bought my first Rigid -- lifetime free battery replacement. :thumbsup:
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
CATERPILLAR 21" PIN ON BUCKET (A52706)
CATERPILLAR 21"...
2017 John Deere 5090GN (A53317)
2017 John Deere...
2017 CATERPILLAR 120M2 MOTORGRADER (A52709)
2017 CATERPILLAR...
8ft Flatbed Truck Body with Axle (A55851)
8ft Flatbed Truck...
New/Unused 200lbs Cast Iron Anvil (A57454)
New/Unused 200lbs...
