StevieRhee
- Joined
- Mar 11, 2023
- Messages
- 2
- Tractor
- ASV VT70 Posi Track
Hi. I recently purchased a ASV VT70. Bloody great machine in my opinion. I busted a hydraulic pipe underneath the body, that connects to the drive. Anyway I had to lift the cab to get at it, and everything went well. Put it all back together and back to work. Until after lunch I hopped in to start it, and blew a 10 amp starter fuse. No biggy, I'll just change it. Blew again, until I worked out that if I lift the cab to a certain height, it will not blow the fuse. I lift the cab with the door open, reach inside and turn the key. But I also found that if I don't lift it high enough, it will blow the fuse. I live in New Zealand, and we sometimes get away with Kiwi ingenuity, but I think that will only go for so long. Meaning I think lifting the cab, will only last for so long. Has anyone experienced this before. Cheers
