ASV RC100 Relief Valve not working correctly?
   / ASV RC100 Relief Valve not working correctly? #11
As far as stalling a hyd motor, that will occur when you are asking the cutter head to do more work that the cutter hyd motor can do , based on the pressure and the GPM's. Loss of pressure will reduce torque.
using a 25 cu in hyd motor,
---------3000 psi
torque = 995 ft lbs
--------2500 psi
torque = 829 ft lbs
0 to 38 GPM will change the cutting speed
As you vary the GPM's, the torque on the motor should be the same, but the velocity at the cutting tips will change based on the GPM's provided.
It takes about 78 HP to produce 38 GPM's at 3000 psi, so you can see that if the GPM's are less, you are providing the hyd motor with less hyd fluid in order to develop the motor HP.
If you stall the cutter motor, you have no flow, lots of pressure. The fluid pressure has to be relieved somewhere.
SUV (A59231)
SUV (A59231)
2021 SANY SY265C LC LONG REACH EXCAVATOR (A59823)
2021 SANY SY265C...
EZ Go TXT Golf Cart (A57453)
EZ Go TXT Golf...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59575)
2018 INTERNATIONAL...
*Selling at Royal Auction Zephyrhills, FL Location* (A59228)
*Selling at Royal...
2005 Toyota Highlander SUV (A56859)
2005 Toyota...
