ASV RC-60 with parasitic power drain on battery
   / ASV RC-60 with parasitic power drain on battery #1
DPHCPA
ASV RC-60, Ford 3930
I have a 2005 ASV RC-60 that has a constant 3.4 amp power drain with everything off. I have tried to locate it by pulling every fuse in the panel. I have also pulled the BOTH main power fuses and it still continues. I have not pulled any of the (4) AUX loader relays because it looks like they get there power directly from a fused link in the panel. ANY suggestions would be greatly appreciated.
On another note - Would this cause the alternator to put out almost 16 volts when charging?
   / ASV RC-60 with parasitic power drain on battery #2
I HATE electrical problems. A good multi-meter and a lot of patience.
   / ASV RC-60 with parasitic power drain on battery #3
Your voltage regulator has taken a dump. Pull the battery wire off of the alternator and see if your parasitic power drain is the alternator itself.
Also possible that the battery itself has an internal short. This you test by disconnecting the battery and if it drains on its own, well that is a problem.
   / ASV RC-60 with parasitic power drain on battery #4
Good advice ^^^^^^. If that isn't the problem,we can go through some other tests.
PALLET OF JACKS AND STANDS (A53843)
PALLET OF JACKS...
1994 Fontaine 48 ft. T/A Float Trailer (A53117)
1994 Fontaine 48...
2000 Mack CH613 Day Cab Winch Truck (A53117)
2000 Mack CH613...
2015 Ford Focus (A51694)
2015 Ford Focus...
2006 Kubota L3130 (A50123)
2006 Kubota L3130...
2017 Dodge Journey SUV (A51694)
2017 Dodge Journey...
