ASV RC-100 Starter Relay issues...
   / ASV RC-100 Starter Relay issues... #1
redpeppers
ASV RC-100
So my ASV RC-100 has a problem at the fuse box/panel. I recently purchased this machine for a decent price but the slot for starter relay has degraded from what i believe was caused by hydraulic fluid getting into and on the fuse panel. I got a fuse panel cover but the damage is already done. So basically in a nutshell i can not put the micro starter relay in the slot it is suppose to go into at the fuse box. Does anyone have a wiring diagram for this machine so i can look at how to bypass the starter relay and install my own relay?.
   / ASV RC-100 Starter Relay issues... #2
I just worked on a friends TEREX tracked loader. Is that the same family?
Why would oil wreck the fuse panel? Spraying a good zero residue cleaner into the sockets should clean them. On this machine, one fuse position was bad and had been moved to an unused position. I think, someone tried to JAM in a fuse out of position and bent the socket. I did find schematics on line, but they are a nightmare to follow. Was thinking about taking the PDF to a printer to make a large print, but could not get that done in color and that is a helpful feature of the drawing.
Apparently these machines are not great for their electrics and some end up in flames!
I believe it is in the same family. I am not sure for certain it was from the hydraulic fluid but the socket is damaged beyond repair. I would have to replace the whole fuse assembly box to fix it hence the reason I would like to wire up my own relay. I have search quite a bit and have found no schematics.
   / ASV RC-100 Starter Relay issues... #4
2012 GROVE TMS900E TRUCK CRANE (A50854)
2012 GROVE TMS900E...
Super Material Lift MH1000 (A51039)
Super Material...
2018 FORREST RIVER CRUISE LITE CAMPER (A50854)
2018 FORREST RIVER...
2014 CATERPILLAR 277D SKID STEER LOADER (A51222)
2014 CATERPILLAR...
2017-2023 Ford Super Duty 4x4 Pickup Truck Bed (A49461)
2017-2023 Ford...
MT-500 Tack Trailer (A49461)
MT-500 Tack...
