ASV Leak
/ ASV Leak
I did find that leak last month. I purchase some ultra violet dye for the hyd oil and could see the leak. The valve block was not leaking, over time it would just build up oil and dirt. The leak was from the underside of the hydraullic tank. It had cracked between two of the hose mounts. It took half a day to get out and get tig welded, then another 6 hours to put it all back together the next day...not that fun.
1020 hours....still have not changed the tracks, they are going to fall off before I spend the 6,000 bucks to replace them.
/ ASV Leak #12
i have an RC100 and currently have a small drip coming from the connections at the left drive motor. it really drips bad if i use high speed drive.has anyone else had this?
/ ASV Leak #13
It sounds like you might have a pinched O-ring on one of your drive motor hoses. I had a leak that sounds similar to you on my RC50 and there ended up being a small "nick" in the O-ring.
/ ASV Leak #14
The ASV has developed a pretty good leak coming from the valve block but I can't tell where it's coming from. Any ideas or tricks to find the leak? What's the best way to start looking?
Where do I find a wrench to check the pipes for tightness? It's too tight for a regular wrenchg...
My tracks are about shot...major chunks coming off now...850 hours.
iF YOU ARE TALKING ABOUT THE VALVE BLOCK BELOW THE HYD. OIL FILLER. tHE ARE THREE NUTS ON TOP OF THIS BLOCK. IF THIS O-RING UNDER THIS CAP GOES BAD OR NUTS GET LOOSE IT BLOWS OIL EVERYWHERE.
Agri-X 5' 3pt Mower (A53317)
Agri-X 5' 3pt...
2012 HYUNDAI  HL740-9 WHEEL LOADER (A58214)
2012 HYUNDAI...
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A59231)
2023 Fat Truck...
2025 30in. Forks and Frame Mini Skid Steer Attachment (A59228)
2025 30in. Forks...
Bobcat MT85 (A60462)
2015 Caterpillar Backhoe (A60352)
2015 Caterpillar...
