ASV Aux Hydraulics Problem
   / ASV Aux Hydraulics Problem #1
h2y
La Grange, TX
NH 7840
On my ASV 4810, I'm having problems with my standard flow hydraulics. Namely, I can't turn
the flow on with either the lever or foot pedals. It's like an (electrical or hydraulic) safety feature
prevents me from moving it. Every now & then it will work...but it's gotten a lot worse lately.
I disconnected the foot pedal line to eliminate that as the issue. High flow works like a champ,
always works when engaged. I wiggle that lever to make sure it's off, although that shouldn't
be an issue since I think you can run both flows simultaneously. Anyway, I'm stumped.
   / ASV Aux Hydraulics Problem #2
If those valves are solenoid valves, then I would trouble shoot the electronics, using a volt-ohm meter.
Clip on to each wire and wiggle the bundle and see if there is an open, maybe frayed wire or a wire shorting against metal, etc.
You could also try jumping directly from a power source to the solenoid and see if the solenoid actually work correctly.
You are spot on. 1 of the 3 solenoid coils attached at the bottom of the valve in the hydraulic console
is bad (no continuity). I switched it with one of the good ones and my aux hydraulics lever works fine
and the loader control wouldn't work. Ordered a replacement thru Trackloaderparts for $114, Part 41:
0062-005 on the Hydraulic Console Assy window. The 3 solenoid coil packs are identical so you can
switch around to find a bad one. Thanks J_J.
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2019 Nissan Sentra Sedan (A50324)
2019 Nissan Sentra...
2019 Nissan Sentra Passenger Car (A51694)
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A52748)
2017 KINZE...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
