LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,156
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
yep, not many.
If equal tractors and equal dealers then the one that weighs the most will have an advantage. Looked at Kubota and New Holland. New Holland weighed the most and no regeneration was necessary for New Holland. Everything is automatic with no assistance from operator.Appreciate all the responses. I'm not sure which direction I will go. Between Kubota and New Holland it probably does not matter. Both are great and the dealer support in my case is as well. But of course I must obsess over such decisions regardless.
Good post but is this a typo here?There is a fairly large increase in the amount of nitrogen oxides than a 75 HP engine can emit vs. a >75 HP engine
Comparable “legacy” farm tractors (AGCO, NH, Case-IH, Deere) typically weigh more. Although that doesn’t seem important, it is the most important thing in a tractor.
Weight equals power & stability.
I’d take a 125HP tractor that weighed 14,000lbs over a 150HP tractor that weighed 11,000lbs every day. You can add weight to the lighter tractor, but that does not increase frame strength.
Kubota has outstanding loyalty under 100HP. 20 years ago, they were almost unmatched in what they offered and quality. I think that has changed. CNH and AGCO have decided to get serious in the 100 HP and smaller market.
Kubota now expanding up to 200HP with a 6.7L Cummins power plant makes things more interesting.
The trend has gotten lighter across the board...Comparable “legacy” farm tractors (AGCO, NH, Case-IH, Deere) typically weigh more. Although that doesn’t seem important, it is the most important thing in a tractor.
Or rather more HP in smaller class machines.
But horsepower is NOT a good baseline to compare tractors. You need to FIRST compare the size/series. THEN compare horsepower secondary.
IE: Deere 5-series = Kubota M5 = New holland T5
Deere 6-series = M6 = T6
Deere 7-series = M7 = T7, etc
Because you can have a 5-series, 6-series, and 7-series deere all in the ~125hp range, and all will vastly different capabilities.
