Assorted BX questions
/ Assorted BX questions #1
RayCo
Chester County, PA
Kubota BX24, Case 580 Super L
Since I'm at work, I can't answer these questions for myself. And since all I can do while I'm at work is think about all the things I'm going to do on my new BX anyway, I figured I'd post some questions.
1. Does the BX24 have any way of parking the backhoe and locking it in place? My father-in-law's Case backhoe has some sort of latching mechanism that holds the backhoe in place.
2. The manual specifically says not to use a cigarette lighter in the 12V outlet. Anyone happen to know what amperage you can pull through that outlet safely?
3. Is there a fuse block on the tractor, or are all the fuses inline in each independent circuit?
4. Does anyone happen to have a BX24 owner's manual in PDF format or any other digital format?
Thank you
/ Assorted BX questions #2
Assuming the BX24 hoe is similar to the BX22 yes it has pins to lock the boom and side to side movement. The 22 has a fuse box in the battery compartment.
/ Assorted BX questions #3
You have 2 pins to lock the BH in place, that normally stow by the BH controls. I always use one to keep the BH from drifting down while parked in the garage. The second pin prevents pivot from left to right. Not sure on the other questions.
I have parts PDF's but not the owners manual.
/ Assorted BX questions #4
MOPAULY said:
....I have parts PDF's but not the owners manual.
Mopauly what parts PDF's do you have?
J
/ Assorted BX questions #5
I have the PDF's for the tractor, loader, and backhoe if I recall correctly. Just basically a parts list for each sub unit. Not a service manual.
KBH Tank Trailer (A63689)
KBH Tank Trailer...
20ft. x 8ft. Shipping Container (A65640)
20ft. x 8ft...
90in. Work Bench (A65640)
90in. Work Bench...
2019 Toyota Tacoma Pickup Truck, VIN # 5TFSX5EN2kX065481 (A65563)
2019 Toyota Tacoma...
New 2200lb All Steel Adjustable Gantry Crane (A62679)
New 2200lb All...
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
