Assorted BX questions
/ Assorted BX questions #1
RayCo
Veteran Member
Chester County, PA
Kubota BX24, Case 580 Super L
Since I'm at work, I can't answer these questions for myself. And since all I can do while I'm at work is think about all the things I'm going to do on my new BX anyway, I figured I'd post some questions.
1. Does the BX24 have any way of parking the backhoe and locking it in place? My father-in-law's Case backhoe has some sort of latching mechanism that holds the backhoe in place.
2. The manual specifically says not to use a cigarette lighter in the 12V outlet. Anyone happen to know what amperage you can pull through that outlet safely?
3. Is there a fuse block on the tractor, or are all the fuses inline in each independent circuit?
4. Does anyone happen to have a BX24 owner's manual in PDF format or any other digital format?
Thank you
/ Assorted BX questions #2
Assuming the BX24 hoe is similar to the BX22 yes it has pins to lock the boom and side to side movement. The 22 has a fuse box in the battery compartment.
/ Assorted BX questions #3
You have 2 pins to lock the BH in place, that normally stow by the BH controls. I always use one to keep the BH from drifting down while parked in the garage. The second pin prevents pivot from left to right. Not sure on the other questions.
I have parts PDF's but not the owners manual.
/ Assorted BX questions #4
MOPAULY said:
....I have parts PDF's but not the owners manual.
Mopauly what parts PDF's do you have?
J
/ Assorted BX questions #5
I have the PDF's for the tractor, loader, and backhoe if I recall correctly. Just basically a parts list for each sub unit. Not a service manual.
Man Basket (A65640)
Man Basket (A65640)
Fork Extensions (A65640)
Fork Extensions...
2013 Chevrolet  Express 2500 (A62613)
2013 Chevrolet...
3148 (A63117)
3148 (A63117)
2013 Land Rover Range Rover AWD SUV (A64557)
2013 Land Rover...
2019 FORD F-150 XLT CREW CAB TRUCK (A63276)
2019 FORD F-150...
