Assessment of New Holland TZ25DA BOOMER
   / Assessment of New Holland TZ25DA BOOMER #1
CDNeh
Sudbury, Ontario
New Holland TZ25DA, MF1655
Hi folks,
About my TZ25DA, 4 years in, backhoe, 48" lawnmower, back blade.
I like it, emotionally attached to my 'Little Blue', the engine is great ... HOWEVER:
- Next to Zero power in 'Hi' a 5degree grade is too much
- Zero power in 'Hi' reverse.... a softball size hump is enough to stop it
- Not fast in 'Hi', Frustratingly slow in low especially in winter temp's
- Hydraulics very slow in summer temp's slower in winter
I am at a crossroad - Do I look into 'fixing issues' with retrofits/increasing hydraulic oil lines, summer & winter hydraulic oils for the hydrostatic OR trade the whole *?~!@... package for 'a better worker'.
Comments/opinions appreciated
   / Assessment of New Holland TZ25DA BOOMER #2
Have you checked that the brakes aren't sticking on?
Aaron Z
   / Assessment of New Holland TZ25DA BOOMER #3
Has it been this way since new?Have you changed the HST filters and fluid?
So far, I don't suspect sticking brakes ... when the brake is on the engine strains more than it should there's a le pitch difference.
Yes pretty much, brutally slow and not strong at all in reverse. I bought it with 400hrs. It's at 800hrs now. I changed all the filters and oils twice.
   / Assessment of New Holland TZ25DA BOOMER #6
Does it have a sump screen in the trans case?
Sixdogs' Q sent me to the manual about a sump screen there doesn't appear to be one just filters and I changed those within the last 100hrs of use. I'm thinking I have viscosity issues. I have HYDRAUL 56 in it now, summer/winter. I'm in -30 C temps now. HYDRAUL 50 has a lower temp range. New Holland recommends AMBRA G 134, and F200, something I need to look up.
   / Assessment of New Holland TZ25DA BOOMER #8
I had a TZ25 until last summer, I loved it. I find that the TZ Boomers are a glorified lawn mower. Do you use high revs when operating? I found as long as you keep the revs up nice and high it wasn't too bad. I bought a B2320 Kubota last summer, 3 speed transmission helps a lot, it's a much stronger built tractor. There is a big difference between a compact and a sub compact tractor.
2014 FREIGHTLINER 114SD VACUUM TRUCK (A51406)
2014 FREIGHTLINER...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A51573)
IMPORTANT PLEASE...
Toro Zero Turn (A50324)
Toro Zero Turn...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
Electric Mobility Scooter (A51694)
Electric Mobility...
