Assembling the Country MFG 2 ton dump trailer
   / Assembling the Country MFG 2 ton dump trailer #1
hazmat
Elite Member
West Newbury, MA & Harrison, ME
Kubota L5460HSTC
Step 0 get lucky & semi shows up with lift gate - still a chore to get it off as the crate interfered with his pallet jack. I had to lift up one end with the tractor as he lowered the other on the gate.
As shipped
Step 1 - attach axles using 8" pins
Step 2 - attach wheels (cotter pins)
Step 3 - bolt on tounge
pic 1 instructions
pic 2 axel
pic 3 wheels
pic 4 tounge
Step 4 - flip it over and pin on deck
Step 5 - add floor
Step 6 - bolt on front & back
Step 7 - Slip in wood sides & sheet metal front & back panels
pic 1 tounge details
pic 2 axle details
pic 3 right side up
pic 4 deck
pic 5 complete
grease axles & attach to tractor.
My cylinder & hoses are still in transit - Surpluss center didn't ship them out for 48 hours:( If I had them on hand, I would have installed prior to the floor.
The whole job took less than an hour & only required a screwdriver, pliers & 2 adjustable wrenches. I suspect that it is simpler than the wagon model. I did add a couple washers here and there for the pivots.
   / Assembling the Country MFG 2 ton dump trailer #7
Not really, about 2 hours for me. Would have went faster if I had another person to help with some steps.
   / Assembling the Country MFG 2 ton dump trailer #8
I'm thinking about getting one,will it fit in the bed of a p/u ? I have to pick it
up at the shippers because delivery trucks have alot of trobae with the road and my driveway
   / Assembling the Country MFG 2 ton dump trailer #9
I believe so, if you have an 8 ft bed. You might have to angle it in width wise.
   / Assembling the Country MFG 2 ton dump trailer #10
I picked mine up at the freight terminal with an F150 short bed with no problems.
2015 John Deere 5065E 67HP 4WD Utility Tractor (A49346)
2015 John Deere...
2021 Spartan RZ Zero Turn Mower (A50860)
2021 Spartan RZ...
2025 K1912 UNUSED Metal Livestock Shed (A50860)
2025 K1912 UNUSED...
Mk Diamond MK-101 Wet Tile Saw (A49461)
Mk Diamond MK-101...
1.5 Ton Car Jack (A50860)
1.5 Ton Car Jack...
Caterpillar 730 Articulated Dump Truck (A49346)
Caterpillar 730...
