asphalt milling cost
   / asphalt milling cost
I love the stuff. After about 6 months its almost as hard as a driveway. We get it free. Just have to wait for the milling machine to show up nearby and leave a note for them to call you if they want to get rid of millings.
yea, i would have took all 7 loads for free. I told him when he's ready to give it away come see me.
   / asphalt milling cost #12
I usually tip the driver a bit and he will chute it nice for me.
Works especially well over old stone driveways that are shot (like mine).
Another thing to do is get it stockpiled, then rent a 2 ton or bigger roller. Spread it out as level as you can and roll it. Looks great. I can rent a roller for a day for ~$250
   / asphalt milling cost #13
Sorry OP.
Does it hold up pretty well on a steep drive?
   / asphalt milling cost #14
Sorry OP.
From what I have seen, if it is well compacted on a reasonable base yes, but let's qualify "steep"- flat enough that you can drive up it without stomping on the gas. If the drive is that steep, you may need to pave that section. I have millings mentally filed under other types of self adherent, chemically cementing road base; crushed limestone, fly ash, crushed slag. They can be very hard and very durable, but the need to set, and if you load them up (heavy vehicles, spinning wheels, etc.) too much before they set, they crumble. If you have your own roller and can get after the steep section frequently when it first goes in, it will set faster and be durable sooner.
I would also say that getting millings laid down in summertime heat and compacted in heat really helps. You want to get the tar/asphalt melting and adhering to the other granules.
All the best,
Peter
   / asphalt milling cost #15
i have long drives, so i get random contractors trying to offloading random stuff. just got quoted 1k for a tri axle of millings? i thought this was extremely high, when i can get pea gravel, which looks nicer, for like 500 a load.
aren't millings pretty much useless to these guys, as i know people who have gotten it for free in the past.... maybe its been a couple years for me.
The local road commish spreads them for free if we want them. Always has.
   / asphalt milling cost #16
All the contractors in my area use the millings in the new asphalt mix. They get mixed in in a certain proportion in the plant.
   / asphalt milling cost #17
Not all millings are the same either. Older and "spider webbed" roads that are "dry" don't grind well or as fine as a better, newer road will. These dry millings are not what you want on a hill and will behave similar to crushed stone.
   / asphalt milling cost #18
I got 50 triaxle loads for my driveway for free when I built my house. I paid $5K the last time to have 12 loads put through an asphalt machine and spread on my drive. You can get it dumped around here all day long for free to $100 a load.
   / asphalt milling cost #19
Sorry OP.
I think it would since even the older dry stuff seems to re-bind together. My driveway came from older alligatored roads (lots of cracks) and once spread and rolled it holds well. My one barn driveway is like a shallow river during heavy rains. It would wash the gravel out and need to be reinstalled. Once I installed a layer of millings and roiled them, it has held up much better against washouts. The key is, you need to roll/compress them.
A friend of mine owns a large greenhouse complex and farm. He applies a little diesel fuel spray to his. I cant do that and couldn't because of environment, but he claims it binds the millings together better.
The key for MY driveways is the roller, otherwise I probably wouldnt use millings.
   / asphalt milling cost #20
Last summer I paid $15/ton delivered. It was screened millings. Single tri axle brought 20+ tons. I watched neighbor try to spread some "free" millings and it had a lot of dirt and large chunks in it FYI.
(14) Round Alfalfa Bales (A50515)
(14) Round Alfalfa...
2000 MACK (A50323)
2000 MACK (A50323)
Land Honor Quick Attach Pallet Grapple (A50514)
Land Honor Quick...
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
