Rotary Cutter Asking for anyone's 2 cents...
   / Asking for anyone's 2 cents...
one other thing to look for is the gear box being loose . high hour hogs loosen up the bolts holding the box on.
Thanks for that item to check. I'll make a point of seeing if there is any play or slop in those bolts.
   / Asking for anyone's 2 cents... #22
One of the things I ask a seller is why. Why sell a good working implement. If they bought new the same size it is probably going bad. I gauge the response a lot to determine if I am going to stick around and deal.
Carl
To everyone that offered their sage words of advice, thank you very much.
I went ahead and pulled the trigger. The old girl has a new home.
Pictures aren't exactly worth a thousand words, at least little CL post pics aren't.
She's been abused a bit, but seemingly where it counts, she's still sound.
Gear box checked out good. No pto input or blade output side movement. Pulled fill plug, she was low but clean oil with no water, had obvious signs of some leakage, but it seems like they all do eventually(at least of this grade build), used flashight to see that the vertically standing gear was bright and shiny with no bent or missing teeth, bolts holding down gear box were all tight and movement free, u-joints were greased(with old grease, but you could see ample evidence of over greasing), gear box spun up and down with out binding or making bad noises, haven't run it yet so don't know about smoothness factor yet, keep your fingers crossed.
Some former owner had hit at least 2 noticeable obstacles. There was a dime sized hole punched through right side skirt, and a definite obstruction trying to make it through ride side skirt in the taper portion. Ripped skirt partially from top deck. Who ever welded back was a hack. One 3pt lift arm was kind of mangled in some barn accident and poorly redone also. I have a welder and can redo repairs properly, in time.
Got seller to come down in price another $50, probaly could have gotten him down $75(gave $325 for everything), but it came with a new set of blades(in the box still, how much are blades anyway?), 2 used stump jumpers(little scared about that, what do you have to do to need to replace that item twice????), 3 used sets of blades(2 pretty trashed and tweaked), and another used tail wheel.
All and all, seemed like a good price to take a flyer on a used unit of medium duty. I usually am really only mowing grass and briars. Not 30 acres of saplings, that would kill it pronto.
To anyone who has actually taken the time to read my ramblings, thank you. You've all been a great help.
   / Asking for anyone's 2 cents... #24
Well, congratulations. With that kind of an exam it sounds like a winner.
It hit two obstructions? Mine was in excellent shape and hit two hundred. They can take a lot of abuse. And new blades must surely cost $50-$70?
Bent arms? Mine did that with very little abuse while just backing up.
Sure wish you could post some pictures so we can follow the unfolding adventure. Again, congrats....
2001 Ford F-250 Pickup Truck (A55852)
2001 Ford F-250...
2014 GMC Terrain SUV (A56859)
2014 GMC Terrain...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
iDrive TDS-2010H...
(INOP) 2016 FORD F150 XL SINGLE CAB TRUCK (A51406)
(INOP) 2016 FORD...
Magnolia Trailer with Adams 25 Ton Fertilizer Tender (A55315)
Magnolia Trailer...
2016 CATERPILLAR 304E2 EXCAVATOR (A52709)
2016 CATERPILLAR...
