As if trimming trees in a FEL isn't dangerous enough
   / As if trimming trees in a FEL isn't dangerous enough #1
jinman
Rest in Peace
Texas - Wise County - Sunset
NHTC45D, NH LB75B, Ford Jubilee
Doing it with a hydraulic lift placed in the FEL has got to be even more dangerous. One Boyd, TX resident was killed and another hospitalized when the hydraulic lift fell backwards onto the tractor. It is not specified whether the lift was a scissor lift, but that's all I can see fitting into a FEL bucket. At any rate, the results were tragic.:(
   / As if trimming trees in a FEL isn't dangerous enough #2
You cant fix stupid!
Chris
   / As if trimming trees in a FEL isn't dangerous enough #3
I bet at least one of them thought "I wonder why others don't do this".
   / As if trimming trees in a FEL isn't dangerous enough #4
I think someone on here was going to attempt to do that...:confused2:
   / As if trimming trees in a FEL isn't dangerous enough #5
Yeah..... I'm gonna guess it was one of those small one man lifts.
   / As if trimming trees in a FEL isn't dangerous enough #6
Someone's mother and father were related!
   / As if trimming trees in a FEL isn't dangerous enough #8
Dumb, but still a drag for the poor guy who got killed.
   / As if trimming trees in a FEL isn't dangerous enough #9
[ A man was killed near Aurora Friday after he fell out of a hydraulic lift onto a tractor. ]
falling backwards onto the tractor and on top of Marcum
What I am getting from the first post is that the second person fell out of the lift and fell from some height , killing himself, and hurting the other person. I don't believe it said that the lift itself fell on him. The railing or something on the lift apparently came loose. The lift may have been safe enough, but the person wasn't.
I think we all have made some dumb mistakes, but this one was fatal for his friend.
   / As if trimming trees in a FEL isn't dangerous enough #10
A sad event indeed, The survivor will probably never forget the deed...
2025 New/Unused LandHero 40 Gallon 2-Stage Air Compressor (A51573)
2025 New/Unused...
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
2019 MACK GR64F TANDEM AXLE CEMENT MIXER TRUCK (A52577)
2019 MACK GR64F...
2017 Ram 5500 Chassis Crew Cab Reading Service Truck (A52377)
2017 Ram 5500...
Lot of 2 Loader Tires (A51691)
Lot of 2 Loader...
GOODYEAR SET OF 9.5-24 AG TIRES (NEW) (A53472)
GOODYEAR SET OF...
