arrrrrrrgh, think i screwed up
   / arrrrrrrgh, think i screwed up #1
fishhead
so i went to test the relief pressure on the cushion valve on my chute rotator and could not get any change either with screw all the way in or out. And a fitting that had previously not been leaking was now leaking like a sieve.
So i pull the connections and inside it appears that some portion of the relief valve shaft extends into the threaded area that the #10 boss connector goes into so that the connector has bottomed out on the shaft and seems to have screwed it up. Does this make sense? valve.jpg20150420_161917_resized[2].jpg
   / arrrrrrrgh, think i screwed up #2
Did you have a pressure gauge in the line before you started turning the screw?
Can you post a picture of the screw?
Is it leaking at the o ring?
1968 John Deere 4020 with 7ft Mower (A51039)
1968 John Deere...
2015 FORD F-250XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-250XL...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
2013 Acura ILX Sedan (A50324)
2013 Acura ILX...
2014 VOLVO VNM DAY CAB (A51222)
2014 VOLVO VNM DAY...
1996 Lincoln Town Car Sedan (A50324)
1996 Lincoln Town...
