ARRRRRRGH!!!!!!! Broke my tractor.... Engine Block went SNAP...
   / ARRRRRRGH!!!!!!! Broke my tractor.... Engine Block went SNAP... #151
KrisHansen said:
That's basically what I'm doing. yeah, I'm tempted to say to heck with New Holland and go get the Kubota I should have in the first place.
the thing is, I like the size of this machine. Not too big, not too small. The Grand L is MUCH bigger... I don't think it would fit in my garage, which the 33D does, perfectly.
My dealer sells significiant New Holland and Kubota CUT's. If you talk to my dealer and walk around his yard and shop, you'll find far more Kubota's with damage like this than New Hollands. I've bought numerous New Hollands from him and everytime I try to buy a Kubota he steers me back to New Holland. He know how hard I use machines and tells me Kubotas are just build lighter (less strong). Last time I was there I saw a Kubota 3030 with less than 10 hours on "snapped" where the loader attaches near the center of the tractor. I was told that the owner simply pushed the bucklet into a stump off center.
I'm not sure what hapened to Kris's machine but I would bet it is not bad engineering. I've seen failures like this caused by things as simple as the mounting bolts not torqued correctly.
Andy
Andy
Kubota AND New Holland on the same lot?
I know all machines have weaknesses and strengths. I'm sticking with New Holland, I really like my dealer, they have been great through all of this.
With the bracing on the Grand L, I'd be surprised to hear it broke, but cast iron is cast iron, it breaks..
MessickFarmEqu said:
I also sell them both. I would not agree with his opinion.
Naturally. everyone is entitled to his opinion, even if it's wrong.
:D
   / ARRRRRRGH!!!!!!! Broke my tractor.... Engine Block went SNAP... #155
dynasim said:
Iron Horse,
If the "probably flawed" block had failed while Kris was using the 3-point to carry near its maximum load, would you have made the argument that the 3-point design was faulty?
From the limited evidence I have read, the block was bound to fail, sooner or later(note the evidence of an old rusty crack, and a new crack).
What you seem to be saying is that tractors should have secondary frames to prevent the 1 in 400,000 chance that a casting flaw will fail. I would disagree, as have most tractor manufacturers.
Chris
I do'nt believe it was a casting flaw , i believe it was simply a bad loader frame design that terminates at that point and directs all the forces to that point . As for rust in the crack , you dont open your eyes very often do you . Bare cast iron will rust overnight just with the damp air not to mention snow . I think theres a 1 in 400,000 chance that you are qualified to say anything .
   / ARRRRRRGH!!!!!!! Broke my tractor.... Engine Block went SNAP... #156
Iron Horse said:
i believe it was simply a bad loader frame design...
Then explain why there haven't been more failures reported.
Iron Horse said:
I think theres a 1 in 400,000 chance that you are qualified to say anything.
What are your qualifications for determining what's a bad design?
   / ARRRRRRGH!!!!!!! Broke my tractor.... Engine Block went SNAP... #157
Anyone with half an ounce of common sense can see that the design puts all the stress on that one point instead of spreading the load throughout the structure . Have you not seen an arched bridge over a river ? Do you think it would be a good design if instead of using one arch to go from bank to bank with no piles in the middle (uniform spread of weight throughout the structure) they used two arches which meet in the middle with no pile underneath the meeting place of the arches ? Where do you think the stress point of the span would be ?
   / ARRRRRRGH!!!!!!! Broke my tractor.... Engine Block went SNAP... #158
Iron Horse said:
Anyone with half an ounce of common sense...
could conclude a design flaw would result in more than one failure.
   / ARRRRRRGH!!!!!!! Broke my tractor.... Engine Block went SNAP... #159
Casting Flaw or Design Flaw, the fault still belongs in the same place whether it was the engineers or quality control
   / ARRRRRRGH!!!!!!! Broke my tractor.... Engine Block went SNAP... #160
Neil
I agree everyone has different experiences. I've just seen a bunch of mid size Kubotas that had cracks in them on his lot.
Talking with the Service Manager & GM confirmed what I saw.
Andy
PALLET OF MISC PARTS (A58374)
PALLET OF MISC...
2003 Sea Ray SLX 29' (A56859)
2003 Sea Ray SLX...
Sakai SV505 Vibratory Roller (A53317)
Sakai SV505...
2019 Dodge Charger Sedan (A56859)
2019 Dodge Charger...
2016 Ford F-350 Super Duty Pickup Truck, VIN: 1FT8W3DT1GEB84319, Crew Cab, 4x4, Steel Flatbed (A59076)
2016 Ford F-350...
2025 FUTURE X-DM43 SKID STEER DISC MULCHER (A58214)
2025 FUTURE X-DM43...
