Arrrgh! Can't get hydraulic filter off
   / Arrrgh! Can't get hydraulic filter off #1
Homebrew
Morgantown, WV
PT 425
Trying to do my first hydraulic filter change. I know there's not a lot of space in there, but surely there's a better place for the bleeder port and the hydraulic filter. This is ridiculous. I can't get a filter wrench or a filter strap in there to even come close getting off the original filter. Any ideas other than a screwdriver through the filter?
Well...the old leather belt off the waist saved the day.
   / Arrrgh! Can't get hydraulic filter off #4
I have a strap wrench that attaches to a socket set that works well and also a Rigid plumbing strap wrench with a wide belt and long handle. The little wimpy strap wrenches do not work for me. It amazes me how much i have to tighten the filter not to have air be sucked in.
Ken
Ken
I used my belt to tighten up the filter a little also, but didn't want to go overboard. Should I be worried about getting air sucked in? Is it obvious when this is happening? Should I put some oil around the seal to check?
   / Arrrgh! Can't get hydraulic filter off #6
Terry once made a comment to me to the effect that if the filter isn't tight, you'll get oil weeping out. (Perhaps from the oscillation in the pumping?)
Like Woodlandfarms, I use a strap that attaches to a 1/2" drive, and even then I have to use a 30" handle to get the filters off. I do put a 6"x10" drip pan under the filter to catch any of the inevitable oil dripping out around the filter.
I tighten the filter according to the specification on the filter, finger tight, plus 1/2 a rotation.
All the best,
Peter
   / Arrrgh! Can't get hydraulic filter off #7
On mine, i disconnect the motor and purge. I keep retightening until no air comes out of the purge. I usually am staring to dent the can at this point. I REALLY have to tighten. It is scary. I am going to look at it with a mirror sometime as well as feel around and see if i can see what the problem is. I have a spare filter holder as well that i might swap in. (Ebay, $6 with filter plus shipping - i have been seeing them regularly).
Ken
   / Arrrgh! Can't get hydraulic filter off #8
You must have a tiny waist! Mine's like, 38" or more, depending on lunch! :laughing:
Glad you got it removed. :D :thumbsup:
   / Arrrgh! Can't get hydraulic filter off #9
i have to use a chain wrench to get my hydraulic filter off on the 1430. the craftsman rubber strap wrench just wore out and cant do the job anymore. Also, as someone posted earlier, put a large plastic bag under the filter to catch the oil to minimize cleaning up the oil that falls in the tub.
   / Arrrgh! Can't get hydraulic filter off #10
All the best,
Peter
I am surprised at the difficulty you report in removing filters. I tighten as you say but I haven't found them particularly difficult to remove. Do you put oil on the mating surfaces before installing a new filter?
2025 K1119 UNUSED Metal Carport (A53117)
2025 K1119 UNUSED...
2018 Jeep Grand Cherokee SUV (A51694)
2018 Jeep Grand...
2019 Caterpillar 299D2 High Flow Compact Track Loader Skid Steer (A51691)
2019 Caterpillar...
2018 KENWORTH T800 (A53843)
2018 KENWORTH T800...
40' CONTAINER (A51248)
2021 CHEVROLET SUBURBAN (A53843)
2021 CHEVROLET...
