Arms won't move on my MF 65
   / Arms won't move on my MF 65 #1
Pblich
Lebanon, MO
JD 2010
The loader works fine but I can't get the arms to move on the 3 PTH
Well got it figured out. When you lift the loader the arms go down when you lower the loader the arms come up. So I have to put brackets on the stop the loader from dropping so I can lift the arms.
   / Arms won't move on my MF 65 #3
Part of owning tractor. :thumbsup:
   / Arms won't move on my MF 65 #4
Doesn't it have the selector valve under the seat?
   / Arms won't move on my MF 65 #5
I thought the same as Agvg - a selector valve to change from one to the other. You may also need to put the 3PT lever in a certain position.
   / Arms won't move on my MF 65 #6
Selector valve helps. I have the original MF one on my 59 MF-65. You can only use the 3 pt or the loader. You also need the the draft lever in the cup position to have pressure to the selector valve(s).
2007 TRANSCRAFT 48X102 FLATBED (A50854)
2007 TRANSCRAFT...
2012 GMC SAVANA BOX TRUCK (A51243)
2012 GMC SAVANA...
2 Vintage Metal Signs (A48081)
2 Vintage Metal...
2002 PETERBILT 330 CARGO TRUCK (A50854)
2002 PETERBILT 330...
MIDLAND POLY PIPE REEL TRAILER (A50854)
MIDLAND POLY PIPE...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
