Arms won't move on my MF 65
   / Arms won't move on my MF 65 #1
Pblich
Lebanon, MO
JD 2010
The loader works fine but I can't get the arms to move on the 3 PTH
Well got it figured out. When you lift the loader the arms go down when you lower the loader the arms come up. So I have to put brackets on the stop the loader from dropping so I can lift the arms.
   / Arms won't move on my MF 65 #3
Part of owning tractor. :thumbsup:
   / Arms won't move on my MF 65 #4
Doesn't it have the selector valve under the seat?
   / Arms won't move on my MF 65 #5
I thought the same as Agvg - a selector valve to change from one to the other. You may also need to put the 3PT lever in a certain position.
   / Arms won't move on my MF 65 #6
Selector valve helps. I have the original MF one on my 59 MF-65. You can only use the 3 pt or the loader. You also need the the draft lever in the cup position to have pressure to the selector valve(s).
2022 JOHN DEERE 332G (A50854)
2022 JOHN DEERE...
2002 International 9200i Truck (A51039)
2002 International...
NANCE UNDERGROUND CONDUIT BOX (A50854)
NANCE UNDERGROUND...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2014 VOLVO VHD DAYCAB (A50854)
2014 VOLVO VHD...
12 FLATBED W/ 300GAL WATER TANK (A50854)
12 FLATBED W/...
