Rotary Cutter Are your rotary cutter blades free swinging?
   / Are your rotary cutter blades free swinging? #21
Ah yes, 1 11/16" nuts, probably the only application for such in the known universe. Had to a difficult time locating the appropriate 3/4" impact wrench socket - ACE Hardware stocks them. And yes, an angle grinder is a bit loud when you're wedged under a brush cutter while working on the blade edges.
   / Are your rotary cutter blades free swinging? #22
Bill, I used to block up my cutter before I got a tractor with an FEL, but now I always lift it up and lean it against a tree. Like you, I've never had any leakage. I believe the filler/vent was on top when I tilted the cutter up, so it was never in fluid.
I've never had my blades stick like yours. I think the combination of how long it sits between uses and the amount of humidity trapped under the deck might contribute to the sticking blades. I've sure started the cutter turning a few times with the blades partially stuck and had the cutter do a "dance" until it got up to speed, and centrifugal force put the blades into the correct position. /forums/images/graemlins/smile.gif
   / Are your rotary cutter blades free swinging? #23
Yall make me happy that I have airtools! /forums/images/graemlins/laugh.gif
2017 Ford Explorer AWD SUV (A53424)
2017 Ford Explorer...
2016 CATERPILLAR 336FL EXCAVATOR (A52705)
2016 CATERPILLAR...
2016 Nissan Altima 2.5 Sedan (A55853)
2016 Nissan Altima...
2013 BMW X5 xDrive50i AWD SUV (A53424)
2013 BMW X5...
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
