Rotary Cutter Are these type blades (rotary cutter) ok for "typical" field cutting (long grass)?
   / Are these type blades (rotary cutter) ok for "typical" field cutting (long grass)? #1
Richard
Super Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
Until recently, I've never seen rotary cutters with chopper blades & dual blades.
We have NO stalks... just some old pasture land that we now cut. Would this be a good/bad/indifferent style of setup?
I've seen another (also happened to be a Schulte) that had dual blades but no chopper fixed blade.... how appropriate is that style for cutting pastures (that are GENERALLY maintained/cut a couple times a year.... place has been let go for couple years so it's rough in spots)
   / Are these type blades (rotary cutter) ok for "typical" field cutting (long grass)? #2
Re: Are these type blades (rotary cutter) ok for "typical" field cutting (long grass)
I have no direct experience with that cutter, but it should handle your pastures easily.
   / Are these type blades (rotary cutter) ok for "typical" field cutting (long grass)? #3
That blade arrangement is considered as an ultra mulching setup by Schulte. Should do a great job on pasture grass.
2016 Ford Fusion SE AWD Sedan (A53424)
2016 Ford Fusion...
2006 Toyota Tundra 4X4 Pickup Truck (A53424)
2006 Toyota Tundra...
MAJOR LOT NUMBER 260 (A53084)
MAJOR LOT NUMBER...
Honda EM3500S Generator (A55851)
Honda EM3500S...
Hydraulic Hose Reel (A52377)
Hydraulic Hose...
2006 Ford F-350 Forestry Dump Truck (A51692)
2006 Ford F-350...
