3-Point Hitch Are these the correct lift arms?
   / Are these the correct lift arms? #1
Bill MacKay
Lakeville, Nova Scotia
JD 2320
Hi everbody. Just bought a new 2320 with FEL and BH. I have some questions about the 3pt hitch. The tractor arrived with the BH attached and the lift arms etc in a cardboard box marked as for a 2720. Dealer doesn't have another 2320 on the lot at the moment so I can't do a direct comparsion. Hopefully the attached pics will help. Also is it obvious if there is fluid in the transmisson sight glass? I can't tell if it is completely full or empty. I can't see a bubble. I wonder if it may be low as the tractor seems to be noisier then the 2720 I tried out first. Is there a way to tell model year based on serial #? thanks for any and all help.
   / Are these the correct lift arms? #2
The sight glass has a white background, with (usually) amber colored fluid being visible against the white--if you are seeing all white you may want to do a fluid check and fill. On the arms--I can't tell you if they are the correct part number--they look Ok--but I'm sure they look used!
   / Are these the correct lift arms? #3
Those certainly look like used lift arms off a 2720 to me not a 2320 or 2520.
The 2720 has the bend and welds on them.
snyder_man
   / Are these the correct lift arms? #4
First pic is the new style arm for the 2520 and 2720,the second pic is the older style arms for these two tractors.
I don't know what the OP arms are off of. They sure aren't from a 25 or 27.
Could they actually be 2320 arms?
Greg
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A52748)
Heavy-Duty...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2018 Ford F150 Eco Boost Truck (A52384)
2018 Ford F150 Eco...
2012 FORD F-550 SUPER DUTY XLT SERVICE TRUCK (A51406)
2012 FORD F-550...
2021 KOMATSU D39PX-24 CRAWLER DOZER (A51246)
2021 KOMATSU...
