Are these brakes working properly?
   / Are these brakes working properly? #1
MillWeld
Durham NC
Ford 641
Before I describe the problem I need to give my experience with trailer brakes. I installed brakes on all wheels of my tandem (2000 lb empty) trailer. When I pull the brake-away cable the brakes engage and the truck will not pull the trailer without all 4 wheels skidding. When I am pulling the trailer the drums do not warm up. I assume this is correct operating behavior.
With this experience under my belt I installed brakes on my portable ~3000 lb sawmill. (13 wheels only 2 of them). I adjusted the brakes until they locked and then backed off on the adjuster 10 clicks as is normal. To test the brakes I pulled the cable on the brake-away kit and the brakes do not lock and the truck can pull it. I re-checked the adjustment by adjusting till the drums locked and backing off 10 clicks again but - no change. (The brake-away batteries are 2 auto batteries in parallel and are part of the sawmill and has plenty of reserve power.) In actual towing conditions the brakes apparently work because I can stop quicker and quite satisfactorily. The drums are warm after a 12 mile tow (so are the tires but that is another issue). Are these brakes working right?
Bob
   / Are these brakes working properly? #2
3000 lbs on 2 13" wheels is a lot more than 2000 on 4 wheels. I guess I couldn't say for sure, but I wouldn't expect them to lock necessarily with that much weight on them. I look at it as having a 6000lbs on a tandem axle trailer, and in that case I would not expect them to lock. If it feels right while you are pulling, then I would say it is okay. Also, with 13" wheels I would have to assume they are much smaller drums than what you have on the other trailer. With the pin pulled do you feel a good amount of resistance when trying to move it? You could also find some gravel and see if they will lock up on that.
   / Are these brakes working properly? #3
All the law says is the brake away must hold the trailer for 15 minutes. The way we do the check is hook up to a truck but leave the wiring un plugged, pull the brake away, wait 15, put the truck in gear and it should not move at a idle.
If it were in my shop I would tighten 3 clicks and try it again. If that don't work try a few more clicks. I find many times 10 clicks back is too much.
The way we adjust is to jack it up and have a helper spin the tire in a forward direction as I adjust till just a slight drag then back off 1 to 2 clicks.
Chris
   / Are these brakes working properly? #4
that's how I adjust mine.. lifted and spun.. etc.. adjust till drag, then back a hair..
See my comments in red.
I think the mill would pass this test.
If I tighten it more won't that just make the linings contact the drum more all the time and make the drum hotter?
Chris
   / Are these brakes working properly? #7
Can not see any red / color.
Chris
You may get some more heat but you just need to adjust your controller as necessary. Heat is going to happen no matter what with brakes.
Chris
Chris,
My concern is that tightening the brakes will cause more friction between the linings and drum and produce more heat even before the brake pedal is applied. In other words, if the brakes are tightened the linings and drum will be rubbing more all the time. Right? or am I out to lunch?
Bob
   / Are these brakes working properly? #9
Chris,
Bob
if you follow the other advise given
then no, its unlikely that the shoes are draging on the drum all the time with the above method.
FYI its how i set my drum brakes also
   / Are these brakes working properly? #10
Chris,
Bob
No, you want the brakes just a fraction of a mm before touching. This is very rarely possible with brakes because nothing is perfectly round or matching. They kind of need to wear in the first few miles.
Chris
2018 Kubota RTV-X1100C 4x4 Diesel Utility Cart (A51691)
2018 Kubota...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
2007 Freightliner M2 106 Medium Duty Pac-Man RL10 10 CuYd Refuse Garbage Truck (A51692)
2007 Freightliner...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A51691)
2016 Toro...
2011 Ford F-350 KUV Enclosed Service Truck (A51692)
2011 Ford F-350...
UNUSED Folding 4-Step Stool Ladder (A53117)
UNUSED Folding...
