wawajake
Veteran Member
I have a Buhler (Farm King) 5ft rear discharge Finish Mower and I attempted to take the three blades off to sharpen them , but found no way to hold the blade shaft while undoing the large bolt holding blade. The Operators Parts Manual is no help , although it has great blowups and parts lists, and tons of safety warnings. So my questions are what tricks can be used to hold the shaft of each of the blades so I can get them off. I saw no holes thru deck to run a shaft down to hold blade, I tried putting a rod thru the drive shaft , but the blade just turns on the pully due to the belt tension allowing it to slip somewhat.
Also is this blade bolt typically normal thread or is it reverse thread (the parts sheet does not even tell me that it just states it is a 5/8 x 1 1/4 Gr 8 bolt supplied with spindle)
Any thoughts? For now I sharpened the blades with them on the mower , but that does not do a very good job.
