Front-End Loader Are there FEL attachment plates?
   / Are there FEL attachment plates? #11
MossRoad said:
By the way, the Quick Attach feature on the Power Trac line of tractors is completely amazing. It is the main reason I bought mine. I can change implements like buckets, forks, rakes, etc... in 15 seconds without getting off of the tractor. Powered implements like mowers, tillers and brush hogs take about 30 seconds longer because you have to get off the tractor to hook or unhook two hydraulic hoses. Click on my little animated tractor in my signature and that will take you to my website where there are several videos of the quick attach in action. You will be amazed, too. ;)
Impressive videos, you made it look easy.
Jim
   / Are there FEL attachment plates? #12
Mostly scratch, I start with the hooks, pins and 2 slabs of 1/2" steel and go from there.
My 'on hold' grapple project.
   / Are there FEL attachment plates? #13
This was my first project with the JD quick attach.
2" reciever system for my fathers tractor (4410).
Turned his utility trailer into a dump model.
Willl - This is exactly what I was thinking about, but figured someone surely would be making the blank frames/hooks/pins assembly. I saw a couple of members had "shrub buckets" on the front, and decided that what I needed to move some small trees and light replanting or small trenching if I built a tree farm.
Great stuff - just wish I had the skill and tools to build things like this......always capable of trying and learning I guess.
   / Are there FEL attachment plates? #15
According to the JD build your own pages, the 300CX loader for the 990 has an optional skid-steer quick attach, code BW15244. There are also other manufacturers who supply quick attach systems, ATI Corp. comes to mind, but there are others as well. Try an internet search for "loader quick attach". ATI's web site is here:
ATI Corporation - Tach-All(tm) Quick Attach
Hope this is some help.
John Deere 1025R (A53317)
John Deere 1025R...
(APPROX 16) 6" UP TO 20' CHANNEL IRON (A57192)
(APPROX 16) 6" UP...
2015 Ford F-550 Ext. Cab Enclosed Service Truck with Liftgate (A53422)
2015 Ford F-550...
2016 KENWORTH T270 S/A SERVICE TRUCK (A51247)
2016 KENWORTH T270...
EXCAVATOR GRAPPLE (A53843)
EXCAVATOR GRAPPLE...
