Tires Are there any wider tires for JD 3320 available?
   / Are there any wider tires for JD 3320 available? #1
FoxHole
Oregon
John Deere 3320 e-Hydro
Looking for rear tires for JD 3320 that would make the rear of the tractor look wider than the original pare that it came with. I have the 43x16.00-20 R4痴 on the back and the 27x8.50-15 R4痴 on front. I know it takes a certain ratio with all 4 tires to keep the four wheel drive to work properly. I'm looking to get at least 4-8 inches wider on each side of the rear tires.
Is there anyone that knows if there are wider tires that would be able to work on this type of machine? :rolleyes:
   / Are there any wider tires for JD 3320 available? #2
How 'bout wheel spacers ?
Thats an idea:rolleyes:
Wow! Now you got me thinking. How about the ability to have duals on back?:D I'm sure i would have to have some one make me some, but how much spacing you think i can get away with using wheel spacers? Can this be done right to where you can get atleast 4 inches on each side?
   / Are there any wider tires for JD 3320 available? #5
I have Turf specials and they get my rear width out to 64 - 66 inches and that increases the stability quite a bit.
   / Are there any wider tires for JD 3320 available? #6
   / Are there any wider tires for JD 3320 available? #7
Those are the larger R-4's. There has been talk on here that some of the bobcat extensions work on the 4x20 series. Some of the smaller stuff might work on the 3x20, and they were very affordable.
Do you have the R-4 tires turned to the wider setting?
nmu98;
Yes, but I was kind of desapointed with all that work changing them & only giving me 1/2'' on both sides. I will look into the bobcats extensions though & see what I find. Thanks everybody for your replies. Good suggestions.
Kubota BX25D (A53317)
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
2002 Isuzu NPR-HD Box Truck (A56858)
2002 Isuzu NPR-HD...
2016 Hyundai Sonata (A56859)
2016 Hyundai...
UNUSED FUTURE 32"...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 110,951 (A56859)
Year: 2016 Make...
