/ Are there any mechanics that work on foton tractors having fuel related problems that I can't figure I'm near Cleveland Ohio
jim0
- Joined
- Jun 2, 2023
- Messages
- 5
- Tractor
- Tractor king 404 foton
Are you talking about the large o ring on the perimeter or is there supposed to be another on the center piece that threads in. What started it was it would run for 20 to 30 minutes then shut down like it was running out of fuel I checked the filter and it was about an inch low so I blew my lines out and blew air into tank sediment came out so drained tank cleaned lines no start no fuel to injectors changed injection pump now getting some fuel to injectors no start it will fire with ether but start up could I have messed with timing when I changed the injection pump I'm doing this by feel because I have no manuals thanks for the input I will try to send you a pictureWhen u installed the NAPA filter, did u put the top oring on the filter..??
Or UP IN the filter head.??
It must go UP IN THE FILTER HEAD.. NOT ON the filter..
