Are there any mechanics that work on foton tractors having fuel related problems that I can't figure I'm near Cleveland Ohio
   / Are there any mechanics that work on foton tractors having fuel related problems that I can't figure I'm near Cleveland Ohio #1
jim0
Tractor king 404 foton
Are there any mechanics that work on foton tractors near Cleveland Ohio I'm having fuel problems and can't figure it out I'm getting fuel to the hand pump then to the filter then thru ip .disconnect at every point while I use the hand pump then reconnect. The rubber line from filter to injection pump shows decent fuel to start then fizzles out to foam and air bubbles would it make a difference I'm using a fuel filter from napa
   / Are there any mechanics that work on foton tractors having fuel related problems that I can't figure I'm near Cleveland Ohio #2
Do u have a mdl number of your machine.??
Any chance you can post a picture of the fuel system.?
What started this fiasco.??
   / Are there any mechanics that work on foton tractors having fuel related problems that I can't figure I'm near Cleveland Ohio #3
Filter brand shouldn't make any difference at all as it is on the pressure side of the lift/priming pump. You are sucking air on the upstream side of the lift/priming pump. It's likely you have a restriction between the tank and the lift/priming pump. Check the small screens and check valves in the lift/priming pump and the sediment bowl and seal (if equipped), and the tank valve.
   / Are there any mechanics that work on foton tractors having fuel related problems that I can't figure I'm near Cleveland Ohio #4
When u installed the NAPA filter, did u put the top oring on the filter..??
Or UP IN the filter head.??
It must go UP IN THE FILTER HEAD.. NOT ON the filter..
   / Are there any mechanics that work on foton tractors having fuel related problems that I can't figure I'm near Cleveland Ohio #5
What was the last thing you did before this happened?
   / Are there any mechanics that work on foton tractors having fuel related problems that I can't figure I'm near Cleveland Ohio #6
The NAPA filter is the secondary filter. If it was installed incorrectly there would be fuel all over it when the priming pump was operated. The joke primary "filter" is a small nylon screen in the banjo fitting of the lift/priming pump.
   / Are there any mechanics that work on foton tractors having fuel related problems that I can't figure I'm near Cleveland Ohio #7
Air could be leaking in around the hand pump plunger. I don't remember for sure but I think it just an O-ring.
What does the sediment bowl look like. Some of them have fine screens in the top above the bowl and you have to take them out to clean it.
Some tanks have finger screens in them as well as the finger screen in the banjo fitting at the lift pump inlet.
   / Are there any mechanics that work on foton tractors having fuel related problems that I can't figure I'm near Cleveland Ohio #8
If you have this type of plastic fuel line, it could be the source of an air leak.
   / Are there any mechanics that work on foton tractors having fuel related problems that I can't figure I'm near Cleveland Ohio #9
Sediment bowl.
Sediment bowl screen with dead diesel bugs.
Banjo bolt screen.
   / Are there any mechanics that work on foton tractors having fuel related problems that I can't figure I'm near Cleveland Ohio #10
Lift pump assembly. The priming pump can go on either side. The two white things with spring are the check valves that make the pump work. The round black cylinder in the center is the lift pump plunger.
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
1994 Toyota 6000lbs 2 Stage Forklift (A53472)
1994 Toyota...
2023 Bobcat T66 (A50120)
2023 Bobcat T66...
2013 JOHN DEERE 470G LC EXCAVATOR (A51246)
2013 JOHN DEERE...
New/Unused 12ft x 7.4ft x 8.2ft Container (A51573)
New/Unused 12ft x...
706075 LOT NUMBER 81 (A53084)
706075 LOT NUMBER...
