Are Kioti FEL's self bleeding?
   / Are Kioti FEL's self bleeding? #1
carpenter383
Platinum Member
Indiana
Kioti DK40SE
I was just wondering if my kl401 FEL is self bleeding? I'm coming up on my 50 hr service and when I change the hydraulic fluid will I have to bleed the system? TIA
   / Are Kioti FEL's self bleeding? #2
Yes, just operate the joystick slowly to cycle the cyclinders in and out.
   / Are Kioti FEL's self bleeding? #3
As Kennyd says, you don't need to do anything special after changing out the HST fluid. Just cycle the loader a few times if you notice anything unusual. I did not find it necessary when I did mine.
Thanks guys! Mine's a gear tractor btw
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A55973)
2019 Allmand...
Toro Three wheeler sand pro (A56859)
Toro Three wheeler...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
LOT OF PIGEON HOLE CABINETS (A52708)
LOT OF PIGEON HOLE...
WhisperWatt DCA-85SSM 85kVA Towable Diesel Generator (A55973)
WhisperWatt...
2007 John Deere 5225 56HP Utility Tractor (A55973)
2007 John Deere...
