Are Hobart arc units good ones?
   / Are Hobart arc units good ones? #1
bunchgrass
N. Idaho
Kubota 8540
I saw this for sale and wondered what y'all think of 'em.
Hobart 500421 Stickmate LX 235 AC Stick (SMAW) Arc Welding Power Source $300
   / Are Hobart arc units good ones? #2
I wouldnt buy an AC only machine and for just a bit more than that price you can get an AC/DC. You have much better arc characteristics and better choice of welding electrodes with DC. As far as brand name, Hobart are good machines
Oops - sorry Gary. I didn't even look at what I posted - just thought it had all the info. Here's a bit more on the Hobart.
235 amp AC output
* 160 amp DC output
* 15 ft electrode cable
* 10 ft work cable
   / Are Hobart arc units good ones? #4
Since they retail for over $500 the $300 price is outstanding.
If you can stand moving around 100+ pounds then you will likely be very pleased with the unit.
If you are looking for DC only and light weight you may want to look into an inverter welder.
A lot depends on what it is going to be used for and where it will be parked. I've needed 200+A in DC when running 3/16" Stoody 31 hardfacing but that may not be a need of yours.
   / Are Hobart arc units good ones? #5
I have the Hobart Stickmate LX AC/DC stick welder (220 VAC input power). Paid $350 at Tractor Supply about 4 years ago. It's a good welder. I've had no problems at all. I usually weld with 1/8" rod (7014, 7018, 7024) on DC positive.
   / Are Hobart arc units good ones? #6
If it's new that's a good price, used it's so-so price. I'd have a tough time spending that much if I could find a good used one for $200.
My AC/DC (Sears branded Century) was less than $150 in well used condition. Not much to go wrong with these, so if it works ok now, used is a safe bet in my limited experience.
I have a few less amps, 230/140, but other than that about the same.
I built a rolling cart for mine, they are heavy ..
Sean
   / Are Hobart arc units good ones? #7
even the ac only units are heavy.
but at that price.. I'd buy it. i lovemy 235ac model dc would be that much better..
soundguy
   / Are Hobart arc units good ones? #8
I have that exact welder........that is a steal. It is the exact same welder as the miller thunderbolt with different paint.........confirmed by the miller welding web moderators. You wil never out grow that heavy solid state machine
2020 JOHN DEERE 7R210 LOT IDENTIFIER 165 (A53084)
2020 JOHN DEERE...
2018 WACKER NEUSON RTSC3 ROLLER (A53426)
2018 WACKER NEUSON...
2018 HINO 195 16FT BOX TRUCK WITH LIFT GATE (A53426)
2018 HINO 195 16FT...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
Deere 333E (A50123)
Deere 333E (A50123)
2003 HONDA RANCHER 350 ATV (A51247)
2003 HONDA RANCHER...
