Are Hanson tools OK??
/ Are Hanson tools OK?? #1
banjodunn
Ararat Vic Aus
G'day all I am looking for a set of metric taps and dies, now my local snap on man is trying to flog me his stuff at a price well that is a little high for what i will need it for ( Close to $600 aus:( ). I am a professional mech and do not mind spending good money on my tools but a quick search on fleabay this morn came up with a hanson brand set that to me looked identical to the S/O set BUT delivered to my door for @$200 aus. They are not something I will use every day but in saying that I do not want it to break the first time i use it either. Hope some of you guys have had exp with this brand and may be able to shed a bit of light on a brand not seen over here. Thanks to one and all
Jon
/ Are Hanson tools OK?? #2
Jon
If they are carbon steel taps and dies they will only last for a very short time. If they are high speed steel taps and dies you should get very good use from them.
/ Are Hanson tools OK?? #3
I'm not an overly big fan of Irwin Hanson taps as I've found them to be brittle and easily broken. Personally I suggest you buy taps as you need them so you get the good stuff. How many times do you need to thread a piece of rod? If not at all, all those dies in the set will just sit there.
I buy Greenfield taps from McMaster-Carr. Pricey? Yep; but they are great taps still made in the USA...at least the last set I bought were.
Now I have no idea where in Australia you'd go for a McMaster-Carr equivalent.
/ Are Hanson tools OK?? #4
When I get back home tomorrow, I will check what kind of taps/dies we have, I know they are very good ones, but I cant remember the brand.
Thanks for the input guys i might just hold off on them, some of the places i will use them are a bit hard to get to so the last thing i want is a broken tap:(. I might just keep looking for some sutton or p&n a couple of good aus brands
Jon
/ Are Hanson tools OK?? #7
I looked at the ones we have, and I couldnt figure out which company made them, (the price tag was over the brand name) but they are HSS, and most HSS taps should work well.
/ Are Hanson tools OK?? #8
HSS (high speed steel) is the way to go. You're OK with what you have for home use. For production work brand names like Greenfield and Cleveland hold up a bit better. Greenfield and Cleveland are expensive and not worth the extra cost for home use.
/ Are Hanson tools OK?? #9
I only use taps/dies about once a year (or less), so even harbor freight carbon steel ones would work for me. I have had some really good luck with these $30 HSS lathe tools, they are better then the old industrial ones we have. (the old ones are HCS (high carbon steel) tool steel though, not HSS)
2022 YANMAR VIO80-1A EXCAVATOR (A63276)
2022 YANMAR...
Landhonor 10" Utility Blower Fan (A66408)
Landhonor 10"...
(10) 6 Bar 20' Continuous Fence Panels (A66408)
(10) 6 Bar 20'...
(10) New CATERPILLAR Keys (A65579)
(10) New...
HPX John Deere Gator (A65579)
HPX John Deere...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
